8th, 9th October
8th, 9th October
Am going to be in Christchurch as Zoe has a Seminar thing about muscles....
Anyone got any ideas for a couple of day trips.... (as long as I've fixed my front hub that it...)
Who knew Prados could fly?
- hosehustler
- penetrator
- Bush Crasher
- hosehustler
Hi all, been chatting to Al,
looking at doing something local on the saturday 8th at this stage, thinking of heading up the Waimak, either mclean's Is or north side, there is some VERY challenging
parts either side, or on the other hand we can make it relatively easy in the same area's
who's still keen
who's still keen
I hate signatures
- hosehustler
- penetrator
- hosehustler
monaro427 wrote:hi tim would be keen to tag along, checked my rear diff and looks like it is a LSD, will be in touch, did you ring that number about the tail gate, heading out there this saturday if you want me to find out how much and se if there is any rust
Hi Craig,
haven't rung him yet, can you check it out for me when you're out there
cool on the LSD, do both wheels turn sme direction when jacked up
tim
I hate signatures
- hosehustler
penetrator wrote:Yeah id be keen to do some of the waimak stuff - how rough are you guys planning on going - I have a standard V6 surfdont want to break anything at the moment
standard trucks welcome, as long as you have rated tow points (hooks) no towballs or std tie down hooks, you're welcome along, it will be as tough or as easy as you decide, most bad spots can be avoided
however some of us tend not to avoid them
I hate signatures
hosehustler wrote:cromcruiser wrote::oops:![]()
you guys from chch could fix bills hubs for him
hey Bill, wats wrong with yur hubs![]()
got heaps of parts here, what do you need![]()
let me know3 so we can help while you're up
I've shredded a hub, so need to replace it, will be popping down the wreckers today, to see if they have one. Only snag is I forgot to count the splines
Only other things I have to get through before the 8th is WOF & Rego. New windscreen being fitted today
- penetrator
Yip that sounds good then hose hustler - got tow hooks all round and a strop which sounds like it might get to be taken out of the packet on this trip
Hope i didnt sound too scared there
its not a waxed and polished shiny I use it for hunting but have seen some of those massive trenches down at the waimak and wasnt too sure what I might be getting myself in for - sounds like fun
- hilux_will
- Driver/Navigator
- penetrator
- hilux_will
- Driver/Navigator
- penetrator
Well i installed my snorkel myself so need to give it a test and make sure theres no leaks!! (seems ok).
Must have been a bit of rain if it was up that high i was in lees valley in the weekend and noticed the waimak was a bit dirty heading out there on sat morn diddnt realise it had got that bad though
4X4ROB wrote:Wet weight of a SWB Safari is 2.3tonnes.
Regards...Robbie
Lets say 1L of oil or diesel has the same specific gravity as 1L of water.
60kg's of fuel
10kg's engine oil
4kg's front diff oil
2.5k'gs rear diff oil
5kg's gear box oil
2kg's transfer case oil
5kg's coolent
2kgs brake fluid and powersteering plus anything else i have forgotten
So a genorous 90kg's more, bearing in mind oil and diesel reqardless of weight is lighter than water.
So more like 2.05 tonnes wet.
A bit of recovery gear, winch, bullbars and bigger wheels etc would certainly have you up round the 2.5 tonne mark quickly.
Anyhow, this has absolutly nothing to do with your trip, so i will quietly bugger off and leave you to it
Have fun!!!!
Pete
