Hi Fweedy, I helped H2O out a bit on his SOA. There's 2 ways you can go.
1: Send it in, pay the bill at the end
2: The H2O method
It invloves; Cutting off the "under" spring mounts, and making "over" ones, new shock mounts front and rear, buying or making new steering components, double carden joint for the front driveshaft, alter gearbox crossmember to take the d-carden/extra angle, cutting through the weld and turning the ends of the front axle tube (the big ball your hub sits on) due to changing the diff angle (to bring the steering back to normal), and I'm sure there were lots of little things like brake-lines, handbrake cables, bump stops, steering stops.... all sorts of stuff....
But at the end of the day, he runs 35's easily, with no body lift or other suspension mods
