The plan:
is to use a bit of 75x100x6 angle iron to wrap around the front and bottom of the front chassis cross member and use the 4 holes that the factory tow hooks mount onto as well as 4 that are on the front of the cross member to mount this to the truck. (may also use four more on the bottom of the cross member and weld to extensions of 50x5mm flat plate onto the end to reach two holes a little further back if i get round to it)
Then to this i am going to weld abit of box section I have off my old bull bar, (think it is 50x50)
on top of that will be two recievers both 65x65x5 and two gusseted tabs of 50x5 for my tow hooks so that they will be up the right way.
then for the winch I am planing on using a piece of 200x400x5mm plate welded to two 50x50x5mm box sections that will slot into the recievers
for bracing between the two bits of box section I will use two bits of 50x50x5mm angle.
here is a rough sketch
Hopefully will get started tomorrow. And at a later date I will put two bits of 65x65x5mm box on my back bar so that the winch can be used at the back as well.
Pete
