Power Steering in a Series
- V8SeriesII
- Winch master
Has anyone else put power steering into a series rover before. Not just a ram full power steering. I have done it with one using bits and peices has anyone got any good links or knowledge of easy ways of do it? Thanks.
- mike
- Last minute Mike
I've got power steering in mine but it is a concequence of the LR discovery chassis it has as its all there standard with Rangies and discoverys. Converting the steering column is another thing though. I've got rid of the old steering box and column and chassis bracket. Taken a rangie one made a bracket to mount it to the firewall and in the process of making the drive to the box longer. Guess all you need to do is jimmy up and mount some drive unit where the relay normally sits and the pump on the enigne
Mike
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
- V8SeriesII
- Winch master
