thanks
any one done one in chch?
adogg wrote:sorry to put a dampener on this but i read recently on another forum,that if you go electric you swap the load that a normal fan creates to the alternator,make sense? cause now the alt has to work harder keeping up with an extra 50-60 amp load and this creates the same or more drag on the same belt/crank you just removed the fan from?? have i lost anyone yet?? ,i`d keep the viscous , but thats just my 2c
on the escudos the ac fan turns on if the computer thinks it is hot , i wired one pair into that and the other to a switch , so if i forget to turn it on it comes on automatically, other wise just take a temp sender out of a jap fwd radiator, what sort of truck is yours? i would have a sender at work. cheersaroma wrote:I think u did loose me but by removing the fan causes more engine load to the alt and you need extra power to run the electric fan did I get that right? heeeee heeee I got given a stuffed alt the other day trying to get it to go its 60 amp std bout 40 amps if it gos I might be almost a winner
spanky what temp does thermo switch work and where did you get it?????
ta folks
adogg wrote:doesnt sound rightviscous fan should just unbolt from the water pump pulley
I never seen or replaced a whole water pump/viscous fan assembly? your fan must be off a v6 as v8 VN`s had a viscous fan like the one hanging in my shed, v6 ones sweet though they move a lot of air
but blow a lot of fuses though ay skid
aroma wrote:well that stuffs that found out this morning the viscous bit is part of the water pump and cant get enough room with it there to mount the fan
well gives me the weekend back f @#$!%^#@$@ all the brackets made and every thing wireing loom roughly made up to
hmmmmm do have a grinder in the garage![]()
