electric lockers
electric lockers
I know I probably could of found the answer here already, but I couldn't be arsed looking back through the old topics.
Anyway, I've brought a 80 series cruiser with electric lockers(factory).
What I wanna know is, when they are engaged should the lights on the dash be flashing or solid.
One of you must have one of these and be able to tell me.
It seems that only the front locker is engaging :?:
mudzilla
Post by mudzilla »
Hi Skid ,, They flash untill they lock in ,, They only lock in low range ( factory ) unless you mess with the wireing . Center diff lock works in Hi and Low range and will also flash untill fully locked in .. :D
markr
Post by markr »
mudzilla wrote:Hi Skid ,, They flash untill they lock in ,, They only lock in low range ( factory ) unless you mess with the wireing . Center diff lock works in Hi and Low range and will also flash untill fully locked in .. :D
Yep this is coorect...
I messesed with the wiring, so mine lock in at any time.... 4x4 4x2 low or high....
Return to “Toyota”
