Newb to this forum stuff.
Have had my 88 GQ for about 10 years, fitted a safari turbo and intercooler around 9 years ago. Modified the PTO setup around the intercooler pipes.
Have just fitted an EGT and boost guage. Found that all this time I was only getting 6psi because i never set the wastegate up properly (it was always slightly open before). Fixed that up and it gives 12PSI boost standard. Have also just fitted a boost controller but not sure i need it. 12psi seems ample to me. One thing i noticed is that the EGT is much lower now because of more air.
I had fitted the EGT sensor after the turbo and kept it below 520degC but have today fitted it before the turbo as i saw on one website that you can get as much as a 200degC temp difference across the turbo.
What limit of EGT should i keep it below with the sensor before the turbo?
Because with the extra boost i want to enrich it some.
Setting up my old GQ Turbo properly
Roge
88 GQ SWB Safari Turbo, intercooler and snorkel, 3" exhaust, PTO, EMU suspensiion, 2" lift, 32" MTRs
Hi
No probably not me. I took off my P plate 3 years ago. Still have it and should sell it. "ACRUZA" if you know anyone interested.
My plate starts with DB now. Put on a safari snorkel 9 years ago.
Did a bit more research last night and other forums confirm Paule's figure of 650 degC before the turbo and a figure of 550degC post turbo.
I dont have a boost compensator. Can you fit them to the original Fuel injector pump? Where does one get one from?
Roge
