I have a bj70 landcruiser. The bushings need to be replaced between the leaf springs and the shackles. Which is the best? I dont have greasable shackles.
Cheers.
Landcruiser Bushings
- Steve_t647
eurothane bushes are stiffer than rubber so are better on the road they also seem to last longer.
Rubber tends to flex better from new but can rip and seem to wear faster, they do feel better offroad tho.
I find the difference in flex is not enough to go for the rubber ones and most eurothane bushes have some lubrication properties in the formulae so I run with them, in my case they were cheaper too and once done you dont want to fight to fit them again any time soon.
