The cold 2.8TD issues continue...
dblancer
Post by dblancer »
Finally took my 2.8TD SWB in to get the cold starting looked at.
Essentially it starts fine, the flow plug light goes on, you hear the "click" of the relay and she starts.
However on cold mornings or at night, it will often sudder quite heavily, so ill apply a little throttle to keep her from being so rough.
I have had it die 4 times while driving soon after starting.
It was weird I was in third accelerating and power simply wasnt happening... it kept dropping to like 2000RPM suddenly all the lights come on and she is dead.
I start her like a flooded engine and she is all good.
She might die upto 2 or so minutes after starting, especially when it cold.
I have taken it to the mechanics.
They have done, a fuel filter.
Changed a glow plug ( one was corroded and couldnt be easily removed, wasnt working too well anyway)
and done a compression check ( it was about 380-400) however he said this was when cold, so not to worry...
I have left with them overnight, they will attempt a start early in the morning.
Im a little worried, they reckoned if it was the fuel pump it would be super costly or even injectors? even suggested it might be worth putting up with at this stage.
Hopefully things will be sorted soon.
Steve_t647
Post by Steve_t647 »
It does sound like fuel pump, the injectors would have to fail in a set to do that. It could also be air getting into the fuel lines droping the diesel back to the tank.
mrplane
Post by mrplane »
i would say your pump needs an overhaul.That is a common problem on 4m40 engine.The seal on the front of the pump leaks and overnight will suck in air causing to die a few times once started in mornings.
DaveM
Post by DaveM »
I would say the same. My safari had the same problems and it was due to sucking air in the pump.
dblancer
Post by dblancer »
Whats a fuel pump worth to recondition? someone estimated like $1000 bucks?
mrplane
Post by mrplane »
i,ve done a few of them, but not sure on cost.Think pump is about 7 or 800 on own, plus labour to remove and refit
dblancer
Post by dblancer »
Im biting the bullet and getting the mechanics who live next to me to get the pump done. Giving them the keys tommorrow morning.
Worried Im going to end up frying the starter motor sometimes with the weird starting...
Alot of people I know are giving me a hard time since I not long bought the truck...
I get "shudda bought a Toyota alot..." haha
mitzipusher
Newbie
Newbie
Re: The cold 2.8TD issues continue...
Post by mitzipusher »
my pajero does the exact same thing its a pain in d ass, i talked 2 a few mechanics they all sed get the seals done in the injector pump they all do it
Return to “Mitsubishi”
