I have some sort of misfire (and so does the vehicle!). The motor is a Quad cam 3.5 V6. It is more than running on 5 cylinders, but it just doesn't sounds quite right, not as even as it was or should be.
It is most noticeable at idle - as mentioned it still runs on 6 but not as healthily as it should.
Has 104,000km and had new plugs at 97 000 when the cam belt was done. They are 100,000km platnium plugs and quite a mission to get at. (removal of inlet manifold)
They have 3 coils which supply 2 plugs each.
I am not a modern electronic dude. and have no idea where to start.
It is worst when hot hot, such as a long working climb off road. It is not very noticeable when cold.
