Wanted LSD
For all Nissan related topics
minefield
Wanted LSD
Post by minefield »
Hi All,
I am looking for a lsd for my 89 swb auto
Graham
Nissan Safari SWB Auto ,50mm suspension Lift , 50mm body lift, 12000lbs winch,
33x12.5x15 Perilli scorpion muds
turoa
Pyro Junior
Post by turoa »
I may have one in the garage.... is just the lsd bit so it doesnt include any crown wheel, pinion, housing etc.
doddzee
Is Doddgee
Re: Wanted LSD
Post by doddzee »
minefield wrote:Hi All,
Graham
What model safari have you got? Sure you dont have one already?
turoa
Pyro Junior
Post by turoa »
minefield wrote:Wanted LSD
you are talking about the diff aye? [/quote]
minefield
Post by minefield »
Yes the complete LSD diff head for a Auto
Graham
minefield
Post by minefield »
A question was asked do I have one ,
I got the bloody cheap and being a safari I though it must have one checked when I got home ; No LSD
Graham
long
auto LSD
Post by long »
i know of a complet Terrano and its auto for $300.oo its been rolled has a few parts missing but all the running gear is in it still
gary_in_nz
Post by gary_in_nz »
hey, just checking, if you lift both wheels off the ground with an LSD setup, and spin 1 wheel, the other should spin in the same direction and put up reasonable resistance??
and with the open diffs if both wheels are off the ground the oposite will spin the other way??
PigFmr
Post by PigFmr »
yes and yes, all four of my wheels turn same direction as i have a lsd front and rear
vince
gary_in_nz
hey vince,
i sent you a PM the other day. I see in your signature there that you want to supercharge your truck. I was just asking how you were going about it, ie where you got the parts and things from, any other mods that had to be done to the engine?? or is it as simple as bolting on a turbo??
cheers, gary
PigFmr
Post by PigFmr »
hello gary
did not recieve your pm, but never mind,i have a super charger off a toyota MR2 , it runs on standard v belts was going to put it where the aircon is as i dont use it,i am still 50/50 on what to do at the moment, would like to do a clutch type system where i can turn the charger off when doing 100km down the road as its not needed ,and flick it on just before you drive into a mud hole, it will be a learning curve for me as never used a charger before or fitted one,all my other road cars had turbos, still might put a turbo on instead,
vince...........
minefield
Post by minefield »
A question someone may be able to answer, I started this thread looking for a lsd, Now i'm not so sure that I dont have one.
To start with my Terrano has a lsd and if you jack up one rear wheel and leave the other on the ground the one jacked up is almost inpossible to turn.
talking to a freind today and rechecking my sarfari just now there is a small resestance it appears to hold and then let go , I have been told that the wrong oil will do that, We have a empty section next door so I tried my s/w and droped the cluch on wet grass only one wheel spin yet with safari both wheels letf there mark.
I know with my s/w jack one whel up with the other on the ground and it turns realy freely
Is there any sure way to tell
Graham
DaveM
Post by DaveM »
I wasnt sure with mine, when I looked again, there was a sticker on the diff which had been painted black. Peeled the paint off, and it said LSD oil.
Bit O/T but do you still want to see the geabox spacers? Might be able to pop through 2moro arvo, if you do, just pm your address again, cant remember the number :roll:
Dave
minefield
Post by minefield »
H i Dave ,
Yes that would be great ,Working in the morningWill be home around 1pm
6 Nautique Place
Thanks again
Graham
gary_in_nz
PigFmr wrote:hello gary
did not recieve your pm,...
...put a turbo on instead,
vince...........
that sounds awesome, keep us informed on how it goes!!
gary
Return to “Nissan”
