Was a Ln 130 2.4 2LT till head cracked , I can get a 3L from hiace van will it drop straight in and will flywheel off 2.4 fit as van is auto or will 3l head fit?
and many thanks to those comments on overheating you were all right I was hopeful.........
Fitting toyota 3L into surf help needed
Re: Fitting toyota 3L into surf help needed
taz01 wrote:Was a Ln 130 2.4 2LT till head cracked , I can get a 3L from hiace van will it drop straight in and will flywheel off 2.4 fit as van is auto or will 3l head fit?
Hey Taz
I did a 3l to 5l upgrade and is pretty much a bolt in job, i guess the 2lt is the same basic block layout
I had to change pretty much all the bolt on stuff like powersteer, aircon, alternator, engine mounts, inlet manifold etc
I had to change the sump also and the oilfilter/cooler housing
other than that, the origional loom plugged into the inj pump and all was well
Would ya want to be selling ya exht manifold and turbo?
if ya need a hand or parts (gaskets etc) gimme a PM
Good luck
Dave
Got a Daihatsu Something, hasn't got a Daihatsu engine.... or diffs.... and it doesn't have windows.... or doors.... but its got tyres....
- rangimotors
taz01 wrote:2lt turbo and manifolds will be maybe up for grabs after i get my beast running sweet will be in a week or 2 yet i am sure someone will have something i want............
unless you bolt it up to the new engine...
