bull bar for escudo wanted
bull bar for escudo wanted afther a bull bar for escudo 91 not the nuge bar thanks
- truck-fixer
truck-fixer wrote:Im in the process of designing/building one for the better halfs escudo. When its complete (hopefully by next weekend) you can check it out for ideas and make one your self or I can knock another one up for you if you like.
Can you post up some pics of the mounting points, It would be nice to see how you managed to secure it, as there is a lack of factory mounting points on the Vitara.
- truck-fixer
Smurf wrote:truck-fixer wrote:Im in the process of designing/building one for the better halfs escudo. When its complete (hopefully by next weekend) you can check it out for ideas and make one your self or I can knock another one up for you if you like.
Will do!! Still in designing process at this stage, but will do.
here's a simple design (idea borrowed from mroffroader)
Checker plate was about 6mm thick alloy, pipe has welded caps on ends and about 3mm thick just got it from scrap metal yard...
then there is just the ARB ones...
this is the winch version... but there is a front hitch mounted in the place where the winch normally goes so you can mount a removeable one in there...
[quote="icekayak"]here's a simple design (idea borrowed from mroffroader)
tidy ..... I like that iceKayak, might have to do one like that for the Mrs Zook
dont have the truck so can't take anymore photos...
basically there was a piece of angleiron ?3mm coming off the bar at an angle on either side, welded to a ?4mm square plate the same size as where the stock bumper mounts (I Think) and then there was 2 hi-tensile bolts going through the stock bumper holes i think... or there happened to be 2 holes there that lined up where i wanted it to go... have a look at the pics and then your truck and should be able to work it out
Full sixe photos here:
http://www.offroadexpress.co.nz/images/albums/4x4matt/DSC01965.jpg
http://www.offroadexpress.co.nz/images/albums/4x4matt/DSC01968.jpg
Yeh... it wouldn't be hard to weld a top loop onto the bar to protect the grill etc if you wanted... but with this mounting i would NOT put a winch or tow hooks on it.
