Any one know what the lock right no for the rear Nissan GQ is
Thanks
Graham
Lockright No's
Lockright No's
Nissan Safari SWB Auto ,50mm suspension Lift , 50mm body lift, 12000lbs winch,
33x12.5x15 Perilli scorpion muds
As far as I can remember they don't do one for the Rear of a GQ. They only make a locker for the H233B Nissan Diff, the code for that locker is 3220.
Page 17 of:
http://www.richmondgear.com/07pdfs/PowertraxSection.pdf
Page 17 of:
Who knew Prados could fly?
I have the front one coming over from Rocky road, but they said in Aus. they have one for the rear and if I had the "no" it may match with one of there dana diff's.
I'm like you changing over form a Teranno
Graham
Graham
minefield wrote:I have the front one coming over from Rocky road, but they said in Aus. they have one for the rear and if I had the "no" it may match with one of there dana diff's.
Ah ok, you mean a Lokka...
Part numbers are scarce...
http://www.4wdsystems.com.au/gfx/specials_2.pdf
Shows this:
Patrol MQ, GQ, GU some $499
Thats as much as I can find
3 page of google hits:
http://shop.land-cruiser.ru/index.php?productID=799
Thats a 2 pinion though, I think your rear will be 4?
http://www.genie4x4.com/shop/product_in ... cts_id=110
Thanks for the info , Albundy and some of my mates think I should stick to a slippery in the rear and thinking about it I might go that way, I just need to find a 4.3 ratio slippery, As I have a lokka coming for the front
Thanks for the help
Graham
Thanks for the help
Graham
