nzdncjw wrote:what a good and easy to check the vacum from alternator?
thanks
yep, put your finger over end of pipe
nzdncjw wrote:...I have gotten hold of a 1975ish 40 for nearly nothing... YAH! it has the manual engage system box on it... Now the part where the linkage joins on is different so its unfortunately not an easy bolt off bolt on fix! I will have to pull both boxes out and swap the manual engage part over - bit of a job!...
nzdncjw wrote:OR
Your transfer box is a split transfer case which Toyota started producing around 1980, all the earlier transfer cases are different and you cant swap over the manual engagement. Have a look at your 1975ish 40 but its unlikely its had a split transfer case put into it
Hey Chris, I'm just about to switch from a vacum operated to a manual 4wd actuator.
Haven't got into it yet but have had the vacum unit removed on the transfer case which leaves the same lever as is visable on the manual system. I'm planning on using a manual lever from an older box which I reckon with a little modification will fit in nicely. Should be a bit easer than splitting the transfer case.... although I haven't tried it yet
If your vaccum pump was worn out ,you may also have problems with enough vaccum to operate the brakes.
