Smoky Cruiser motor 13B-T
brakes-shocks-lockers-etc
kruzin
Post by kruzin »
I have an 89 MWB Landcruiser with a 13B-t motor in it which blows a bit of white/grey smoke on cold start-ups. I have only had it a month or 2 and its been doing it since i bought it. It has had a recent engine rebuild 1000 or so kms ago, but didnt have the injectors or diesel pump done at the same time. Im just wondaring if it is a typical for the direct injected diesel motor to do that when its cold, or do i have a fuel mix problem etc..
Is it starting first time or are you priming it a bit?, my 2L-te has a bit of a puff on startup but then goes away....
basics
Post by basics »
mine also if its very cold, hopefully its just normal :?
kruzin
Post by kruzin »
I give it a pump or 2 before turning the key. Its a bigish puff as it starts up then its a small steady white puff
Jungle
Post by Jungle »
Not completely sure of myself here. But a diesel has injectors that are powered by a mechanical injector pump which takes power off the engine.
Therefore, pumping the throttle will only open and close the throttle body or butterfly. Don't think the diesel has a mechanical pump like a petrol has on a carbi.
Does that make sense.
My 13BT and 1HDT both make a white puff on start up and then smoke alittle after that. I'm putting it down to injectors not being A1.
George
mudlva
Post by mudlva »
pull it out :cry: and throw a 350 in the hole. fixes the problem of worn injectors :lol:
kruzin
Post by kruzin »
Thanks George, I might have to get the injectors looked at then
kruzin
Post by kruzin »
Starter motor packed up in the weekend. Replaced it and shes startn like a brand new moter now, with much less smoke! Must of been excess diesel smoke due to the delayed start.
