Can somebody tell me whats gone wrong.
I have a Surf 91 model 2lt turbo diesel 2.4 and she had problems which everyone here in zim said was a faulty ECU but in the end turned out to be a cracked vacume pipe from turbo inlet to exhaust gate but since then she has started to burn excessive oil when idleing and low revs up to 2000 rpm when she suddenly burns clean and if you rev to 2000 ie in first no oil only when it drops below 2000 then clouds of blue (oil)smoke.....whats gone wrong and how do i fix it here in Zimbabwe
Ok I'm guessing the vacuum hose in question is actually the wastegate actuator boost line. When this is disconnected or develops a serious leak you effectively have no wastegate and therefor unlimited boost.
Given your symptoms, my first thought would be you need a turbo rebuild, other members here will be able to help you better. A bit more info on the engine and it's history would probably help.
