Nissan Mistral Workshop Manual
moss
Stropper
Post by moss »
Does anyone want a NISSAN Mistral Workshop Manual.
Or any of those how to docs for mainteance,
Here is a link to download all the Adobe Documents for the
Terrano 2 Workshop Manual, same running gear at the mistral
http://bebrs.pie-dabas.net/Webs/Terrano/R20/ :lol:
kiwipete
Post by kiwipete »
What info are you specificaly after, ie. can you narrow it down a bit for us?
Ph 0212078472
moss
Stropper
Post by moss »
Little Newbie calling up to the Big Fellas. Can you help me get my hands dirty. I have a Nissan Mistral 95 LWB TD27 R20. 285000km and smooth, no smoke. I have upgraded the battery and Alternator as the Standard one did not power all the extras I have. (i.e. Satellite TV. Two Audio AMPS. Touch Screen Monitors. Xbox, and all the Electronic Tools of my Trade(Computer Nerd). I have upgraded the Shocks and can Change the Engine Oil and Filter, can change the Fuel Filter and Air Filter, But I know nothing about the rest.
Should I do any of the following? What else can I do for Mainteance/Improvements?
1. Change the GearBox Oil and Gearbox Oil Filter?
2. Change the Diff Oil?
3. Change the Wheel Bearings?
4. Does the Aircon have a Pollen Filter?
5. Sway Bar/ Torsion Bar Upgrades?
6. Any other Grease or Lube Points?
You Guys with Grease Blackened Hands are Gods. Pitty your not All Blacks. :D
Hahahaha good choice of Name....do you have the ear spray as well :lol:
Try these
http://pdftown.com/Nissan-Pathfinder-19 ... anual.html
moss
Stropper
Please Help Before all my hair falls out!!
Post by moss »
Silly Me I Failed the IQ test.
Thank for the link, but it shows Pathfinder Petrol engines? I have Nissan Mistral 95 LWB diesel TD27 R20.
Guess some of the running gear is the same, But I cant find my engine stuff?
moss
Stropper
Found it Nissan Mistral Terrano Workshop Guide
Post by moss »
Found it, If anyone needs a copy just PM me and i can pass it on
kiwipete
Post by kiwipete »
moss wrote:I have upgraded the battery and Alternator as the Standard one did not power all the extras I have.
What did you use for your new battery and alternator. I have a terrano with the same engine and the alt has the vaccy booster on it.
Have several PDF docs here for the TD27 for these, will send them off to you. PM me your address details please.
Ph 0212078472
moss
Stropper
Post by moss »
For the Battery Just a NS70 did the job
for the Alternator yes your right mine too has a Brake Vacum Booster not to easy to find a replacement I upgraded from the Standard
Hitachi 60Amp LR160-426S (23100 43G09 4Z6) to a new
90Amp if you want more info let me know
keeping the 60AMP as a spare as they are very hard to get
moss
Stropper
Here is a Nissan Mistral Workshop Manual
Post by moss »
99 Percecent of the running gear in this manual is the same as the Nissan Mistral, ENJOY, if the link dies, or you need help just PM me.
Just download all the PDF files, You will need Adobe Acrobat Reader to view the docs,
If only I could upgrade my Partner like my 4X4
dave36
Newbie
Newbie
Re: Nissan Mistral Workshop Manual
Post by dave36 »
Mistral in the uk is a bit of an unknown quantity, but they seem to be very popular over there!
I bought one in 2009 straight off the boat from Japan.
its a 1995 2.7 TD and getting the correct manual has proved impossible, all the downloads I find only refer to the later TDI so anything to do with the cabin and the engine is of little use.
I have a poorly performing heater blower, which stinks when the heater is turned up, so I am presuming the air con cabin filter needs changing, problem is, its supposed to be behind the glove box - but it's not!
I have removed the box, the left trim and the metal cross member only to find that that vertical slot holding the filter is not there............................
Another problem i have is stopping in slippery conditions! what happens is this, driving on wet grass or muddy tracks, not needing 4WD, I cant stop the damn thing! with gentle braking the front wheels lock up and the auto keeps powering the car onwards until the revs drop right off - what am I looking for, rear drums or balance valve?
Danielstratton
Newbie
Newbie
Post by Danielstratton »
I have visited this thread for the last few years to find the link the manual. Like the dumbest that I am i didn't save a copy. Please tell me someone else did because the link has now died.
