for sale :New transfer rebuild kit - Toyota landcruiser
adventures_more
Post by adventures_more »
For sale : New complete landcruiser up to 85'( 34mm idler) transfer rebuild kit (Terrain tamer Tk4 Kit ), ibought the wrong one for my cruiser . so collecting dust on the shelf . yours for around $130 , i paid a bit more , so my loss -your gain !
H2OLOVA
Post by H2OLOVA »
split case transfer? I run the H55 5 Speed and have my transfer case apart at the moment hhhmmmmmmmmm :wink: let me know
H2OLOVA wrote:split case transfer? I run the H55 5 Speed and have my transfer case apart at the moment hhhmmmmmmmmm :wink: let me know
your 70# split transfer case should be the 38mm idler kit :?:
H2OLOVA
Post by H2OLOVA »
thats what i thought when i got my low range gears :cry: Not quite sure whats up there??
H2OLOVA wrote:thats what i thought when i got my low range gears :cry: Not quite sure whats up there??
better do some checking :oops:
I had one of those rebuild kits put through my transfercase a few years back but I didnt do it myself so I dont know what size idler it was but its supposed to be the 38mm?
edit*
did you get some of those Marks gears or something else?
H2OLOVA
Post by H2OLOVA »
Sure did :wink: :lol: went to test fit it all on Fri night and i have 34mm idler. I took it as a given it would be 38mm. They have a 34mm kit here in Ch Ch but only for a 4 speed, and because its a public holiday in Aus today i have to wait until tomorrow to find out what differences there are between the kits, hopefully they can mix me up a set from what he has here, otherwise will have to wait for it to come from Aus :cry: :cry:
I take it you got the kit that also has the 8% high range reduction, I'll be waiting for the feedback once you've got it all sorted :thumright:
H2OLOVA
Post by H2OLOVA »
8% high range 55% low range 8) 8) Might finally be able to get some power from the 3B :? I'm gonna need them when i borrow Rok or Riks tyres :wink: It'll be interesting to see how much difference it makes, want to go to a 37" tyre (4 of them actually :lol: ) So i at least have a chance of keeping up with all the big boots that are starting to appear down here :?
rokhound
Post by rokhound »
H2OLOVA wrote: So i at least have a chance of keeping up with all the big boots that are starting to appear down here :?
Bring it on 'Cruiser boy :lol: . Looking forward to seeing how this kit sets up for you Jase.
H2OLOVA
Post by H2OLOVA »
start here and then add the toybox 8) end up with about 350:1 how stupid is that :wink: But means that i'll be able to turn the 54 inch boggers no trouble :wink: :wink:
kaney
Post by kaney »
H2OLOVA wrote:54 inch boggers no trouble :wink: :wink:
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
what u compensating for with them :twisted: :wink:
toymota thats stock standard.
adventures_more
H2OLOVA >>> Easy to find what size idler your Transfer has , on the rear of your case looking back towards the engine , you will have the input shaft/gear plate ( Top left ), then idler shaft ( Middle ) , Output shaft ( Bottom right ) . Just measure the round section of the end of the idler with vernier's ( i have digital version ) or tape measure or rule if you don't have one .
Most Alloy split transfer case's before 85' are 34mm idler version . i bought this kit thinking mine was the 34mm seeing as it's a wee prado , but it comes down to the year of the vehicle it came stock in not the weight or power of vehicle ( unless its been swapped out ) ?
adventures_more
SOLD the kit today !
