I have a chassis, front and rear coil sprung axles & mounts and an inclination to build. (must be road legal)
I have done alot of searching but not come up with anything in one spot that would suggest advantages and disadvantages of differing designs.
Such as 5 Link (eg rear 80 series)
3 link (eg front Prado, RR, GQ, 80 series)
3 link + panhard
Triangulated 4 link
A frame (RR)
X link (modified 3 link)
Possibly 5 link might be a bit unstable on the front? Rokhound - looking at your pics you have 5 link front?
I am not after extreme articulation but I have always been disappointed with standard 3 link Prado setups. having just taken the front of one apart, looks like the shocks are about 2 inch's to short for a starter. I suspect the arms may bind before that point is reached however.
Which leads me to mounts. RR's seem to flex pretty good in the front and have a pin mount on the chassis
where as the Prado, 80 series have the eye
Is one type more suited - the eye is good for more straight up and down but when articulation is req'd it also has to move sideways??
It will not be a daily driver - more a play vehicle. Ride well over rough surfaces at mod speeds, suitable to drive on the road. Wow what a post.
Does anyone have any good links they wish to share?
