I'm looking at buying a Gen 2 3.5 Pajero.
The owner says it uses about 1 litre of oil between changes.
How bad is this?
What is the usual cause?
Thanks
Jamie
Gen 2 oiil usage
Depends how often he changes the oil
Most likely it is valve stem seals. Normal Mitsi thing. Mine uses more than that, probably 3 litres over 10000km which is still bugger all. To replace them with the head on is quite difficult otherwise its heads off - i'll be doing mine when I take the heads off shortly (another issue)
8 litres does 10000km including oil in sump. It does it when on overrun going down hill off throttle. As little as mine uses i have only ever noticed it once going down a long hill in 1st low. If you can see blue smoke it is burning alot more than that.
Hope that helps
Hope that helps
