Toyota transfer case bits
mudmike
Post by mudmike »
Hi I'm looking for two bits for my kzj78 case, need the front output shaft and the 2 - 4wd shift fork. I hope someone has a busted case out there that has the bits spare. I think any 70series 5spd has same case?
thanks
adventures_more
Post by adventures_more »
I just picked up a good "kzj78" 2nd hand transfer case on the weekend , plan to replace mine this weekend if not the next ( too noisey ), you can have the case that i pull out - its from a 89" LJ71 & is identical to the kzj78 case as far as i can see , same 38mm idler version ! where are you ? I'm in Chch !
Hmmmm LJ71 ..... Am I able to get the rear output shaft seal off that stuffed transfer case?
Any other bits spare? :lol:
Jerry wrote:Hmmmm LJ71 ..... Am I able to get the rear output shaft seal off that stuffed box?
Can you not get a new seal Jerry, a leaking secondhand seal's got to be a last option :?
its not the rubber bit I want its the metal bit in front of it which the driveshaft holds onto...
Jerry wrote:its not the rubber bit I want its the metal bit in front of it which the driveshaft holds onto...
You want the output flange :wink:
yeah that thingy
sig
Jeep Jeep
Post by sig »
you should have asked on sunday jerry i think i,ve got a lj71 transfer in bits in my garage ,it was on the trolley under the hubs
mudmike
Post by mudmike »
Thanks for the offer, but I had to go and get the bits I needed from nz bus and truck, good price and new bits, also doing all beerings and seals while it's out. Daily driver so couldn't wait.
Thanks anyway.
PS these guys are agents for http://www.donkyatt.com
or phone on 0800 287276, got good selection at great prices and the service is very good. much better than toyota for all the odd ball parts.
wjw
Post by wjw »
adventures_more wrote:I just picked up a good "kzj78" 2nd hand transfer case on the weekend , plan to replace mine this weekend if not the next ( too noisey ), you can have the case that i pull out - its from a 89" LJ71 & is identical to the kzj78 case as far as i can see , same 38mm idler version ! where are you ? I'm in Chch !
If your gonna dump it I'll take it off your hands and rebuild it.
Who knew Prados could fly?
adventures_more
Looks like WJW ( Bill ) has got the case - if you give me a look at your engine bay when you pick it up ( I'm looking for a suitable engine for a conversion )
I also have 2nd hand driveshafts & drum brakes from the same LJ71 , they have new gearings on them , all of 3-4 months old - not sure if i can take them off without damaging the bearings ? , I just bought a complete pair of rear axles & disc brakes off a kzj78 .
wjw
Post by wjw »
mines a kzj78 ;-) but my transfer is on its way out too... PM me your address /phone and I'll give you a shout ;-)
