Cheers.
QUADRACER wrote:these take a lot of priming, is easier to fill filter with fuel before installing.
would take feed hose from filter to motor off, and re prime until
fuel is pumping out. this way you can be sure all is primed correct,
small amounts of air will be taken out when motor is running.
some of the newer vehicles will self prime hope this helps
