3.8 v6 into Vitara? Any experience with this?
For all Suzuki related topics
inthemud
Post by inthemud »
Can anyone give me some tips about any problems I might run into. I looked at J18A & J20A but complete with computer, loom, exhaust manifold etc I'd be looking at $2800-$3200. Te Puke parts world say that the mechanical insurance repair centres buy all of these for repairs that's why they cost so much. There's plenty of holden v6's about for bugger all so this is a good option for me. I'm just not sure of the extras I'll run into. Does anyone know of vitaras with this conversion?
Cheers Neal :roll:
Wake up early, go to bed late- you'll have plenty of time to sleep when you're dead!
get in touch with Mark on here under the username blackcruiser .
a guy in his club put one into a vitara and seems fine.
inthemud
Post by inthemud »
Thanks for that
Rotazuk
Post by Rotazuk »
There are a couple around that do the club fun rallies etc , seem to go well .
Extra's you will need gearbox , t/case , front and rear diff's , new front springs :) .
Chris
skid wrote:get in touch with Mark on here under the username blackcruiser .
sorry , I forgot to mention that it has hilux running gear, which would be a neccesity, along with stronger gearbox and transfer case as Rotazuk has eluded to. :roll:
inthemud
Post by inthemud »
Does this mean I will need to modify the front IFS set up to a solid beam axle??
inthemud wrote:Does this mean I will need to modify the front IFS set up to a solid beam axle??
probably, get in touch with someone who's done it, as I mentioned previously
spanky
Post by spanky »
is your original motor stuffed or just want more grunt?. i am putting a v6 in to a vitara for a club /trials truck and you need to change the whole lot like every one is saying. i am using the v6 and 4spd auto with a seperate transfer and hilux diffs.
vaughan
inthemud
Post by inthemud »
yeah probably a bit of both. I don't want to get a bigger wagon but I need the extra grunt at times. I think i've got a small crack in the block so I might use the G16b in my Lj81 project that I've just started. I'll probably need the model/year of diffs, transf case, etc for all bits n pieces to keep me on track. The more info I can get the better.
Cheers Neal
zukmeista
Post by zukmeista »
or you could put an ifs hilux diff in the front :?
Bubba
Post by Bubba »
As you gain info, prices contacts and stuff can you post the info on here so others can see it
ta
Benjamin Franklin
NJV6
Post by NJV6 »
zukmeista wrote:or you could put an ifs hilux diff in the front :?
And Break it.
WACKO
Pyro
Post by WACKO »
And Break it.
i know of a surf with 33s and a lexus that gets a thrashing. its lasting well so far. and with less weight of the vit it should in theory last longer shouldnt it?
Sam
Return to “Suzuki”
