Can anyone give me some tips about any problems I might run into. I looked at J18A & J20A but complete with computer, loom, exhaust manifold etc I'd be looking at $2800-$3200. Te Puke parts world say that the mechanical insurance repair centres buy all of these for repairs that's why they cost so much. There's plenty of holden v6's about for bugger all so this is a good option for me. I'm just not sure of the extras I'll run into. Does anyone know of vitaras with this conversion?
Cheers Neal
Wake up early, go to bed late- you'll have plenty of time to sleep when you're dead!
There are a couple around that do the club fun rallies etc , seem to go well .
Extra's you will need gearbox , t/case , front and rear diff's , new front springs .
skid wrote:get in touch with Mark on here under the username blackcruiser .
a guy in his club put one into a vitara and seems fine.
sorry , I forgot to mention that it has hilux running gear, which would be a neccesity, along with stronger gearbox and transfer case as Rotazuk has eluded to.
is your original motor stuffed or just want more grunt?. i am putting a v6 in to a vitara for a club /trials truck and you need to change the whole lot like every one is saying. i am using the v6 and 4spd auto with a seperate transfer and hilux diffs.
vaughan
yeah probably a bit of both. I don't want to get a bigger wagon but I need the extra grunt at times. I think i've got a small crack in the block so I might use the G16b in my Lj81 project that I've just started. I'll probably need the model/year of diffs, transf case, etc for all bits n pieces to keep me on track. The more info I can get the better.
Cheers Neal
zukmeista wrote:or you could put an ifs hilux diff in the front
And Break it.
i know of a surf with 33s and a lexus that gets a thrashing. its lasting well so far. and with less weight of the vit it should in theory last longer shouldnt it?
