Want to turbo that supra powered lux??
nzhunter
Post by nzhunter »
I have a 7m-ge turbo exhaust manifold for sale am told it can fit a 5m as well. I think a CT26 turbo off the 2L-T engine will fit but not 100% sure
$70
Cheers, Dan
Thrupp
Post by Thrupp »
Im pretty sure a ct20 is off a 2L-T. The ct26 is off a turbo Landcruiser and the 3sgte engines and some supras. Will also fit a TC05 turbo with a four bolt flange. Heres the link
http://www.dieselevante.it/turbocharger ... 00&idcat=2
rangimotors
Post by rangimotors »
do ya no if it will fit a 6m?
nzhunter
Post by nzhunter »
probably will, the 5m 6m and 7m are quite similar engines
rangimotors
yea just a little different sized, and is it a 4bolt flange?
rangimotors
am i right in thinking its pretty much only the head that is different between the 6m and the 7m, 7m being 24 valve 6m being 12, they use the same crank and the 7m but doesn't have counter weights so rev's a little better but makes less torque than the 7m...
realistically for 70 its probably worth taking the risk that it fits
nzhunter
Post by nzhunter »
Bump........Still got it..... if anyone wants it.
