buying tints off the net
Found a good buy? Had some good service? Found a dodgy product or had dodgy work done. Let us all know. We all want to know about the good buys and warn us before throwing our money away on useless crap!
we have threadjacked the other topic long enough.
we should carry on here.
Db, do you think its too dark putting the 5% ones on the back.
I've driven some cars at work that have dark tints and on an overcast day they seem hard to look out of.
philux
Post by philux »
ive got 25% all around, i find it alright at night, just cant really see much in the mirrors out the side rearview mirror is mint :?
philux wrote:ive got 25% all around, i find it alright at night, just cant really see much in the mirrors out the side rearview mirror is mint :?
I thought the legal requirement for the front of every vehicle was 35%
TJ
Post by TJ »
DieselBoy wrote:How different??
Well, put it this way, 5% you can't see anything through, even with your nose pressed up against the window, the 25% you can see through from about 1ft away, BUT, buggered if i would want anything darker on the front windows, i see why its the legal limit!!!!!!
The down side of the 5% is reversing in the dark, even with 100w high level reverse you still can't see shit, you gotta use the mirrors!!!!!!
5% in front is not legal (anything less than 35 percent is not legal in the front), so that is out of the question.
5% percent in the back is not the objective, just between 20 or 35 percent. Thats what I am considering.
TJ
Re: buying tints off the net
Post by TJ »
skid wrote:we have threadjacked the other topic long enough.
May be I can take the doors and hardtop off when I want to drive around with no tint 8) 8) 8)
also DB, how did you get 5%.
I went to look at the website and clicked on VX and it only had the option of 35% or 20%.
http://www.mobistint.co.nz/
will they do what ever you ask for or what :?: :?:
philux
Post by philux »
i think it is to, but i found 35% to easy for peering eyes, hasnt failed a warrwnt yet on it, or no cops goy snarlly about it, i think the rules for the rear windows are a bit different for commercials and 4wds. what i heard was for cars its so they can see the brake lights of the car ahead of the car with the tints... hope that makes some sense
TJ
Post by TJ »
skid wrote:also DB, how did you get 5%.
I had asked the guy and he said he can do whatever I like for the rear, including 5 percent. Front will have to be 35 percent. Apparently he responds by email (doesn't like phones or something).
kaney
Post by kaney »
yep you are right there, the front two windows cannot be darker than 35% and the rest of the vechile can be 5%. the front window sceen cannot be darker than 80ish% (basically nothing)but you are allowed the 100mm strip along the top.
toymota thats stock standard.
MudBum
Post by MudBum »
Hi guys, the law for a 4wd is W/S must be 70% (standard) front door glasses can only be 35% with 5% allowed on any other window.The strip across the front W/S can be a 100 mm but MUST follow the shape of the screen and not be put straight across from one side to the other. 8)
PS. Bronze coloured glass give a darker tint than green glass as well so be careful if your worried about seeing out at night. General rule is most(not all) Jap imports came with bronze and nz new was green glass.
***Prior Preparation Prevents Piss Poor Performance***
Most sports require only one ball - real sports require two.
tallsam66
Post by tallsam66 »
If you make the tint too dark you will have trouble seeing out at night.
I had a 39 Ford Pickup & i had to install a switch to turn off the dash lights..without it was real hard to see.
MudBum
Post by MudBum »
Oops should have put in there too that the cheap tint you buy from TM,Repco and the like are not titanium based so will go purple after awhile ,where as the proper tint guys use the good stuff and this is a lot easier to see thru at night compared to the cheap film. You get what you pay for!!!!
allovermud
Post by allovermud »
hey can you put tints on a soft top? like the sides and back?
cheers,luke
2.5 d/t swb softop pajero...snorkel and torsion bar wind.
kaney
Post by kaney »
allovermud wrote:hey can you put tints on a soft top? like the sides and back?
cheers,luke
yes i reckon you could but i dont think they wouldnt last long.... im thinking would be they would crack and fall off
badnuz
Post by badnuz »
5% is really really dark, i had it on my batty ( all round) and couldnt see f all.... i had my 35% failed on my forester due to the factory bronzing... best to get WOF from a non-testing station cause they tend to be more strick.... or do as i have done and go for a wof on a sunny day and leave the front windows down, helps keep the rest of the inside brighter! I doubt that tint film would stick to plastic glass on the soft top :(
badnuz
Post by badnuz »
Swaney
Post by Swaney »
I was told this stuff is meant to be ok (made in USA SCR Hardcoat)
http://www.trademe.co.nz/Trade-Me-Motor ... 915175.htm
but really i have no idea as i havent used it :D
badnuz
Post by badnuz »
yeah that stuff is great i have done 5 or 6 cars with that stuff recently :) including my own even!
tallsam66
Post by tallsam66 »
MudBum wrote:Oops should have put in there too that the cheap tint you buy from TM,Repco and the like are not titanium based so will go purple after awhile ,where as the proper tint guys use the good stuff and this is a lot easier to see thru at night compared to the cheap film. You get what you pay for!!!!
I didnt use stick on tint..i had the windows custom made & the glass was tinted in the factory.
TJ
Post by TJ »
tallsam66 wrote:I didnt use stick on tint..i had the windows custom made & the glass was tinted in the factory.
Well, they started doing on later model hardtops on Wranglers. When mine was sold, this was not possible - so either I change the hardtop or use a stick on tint, really hard to decide which I might go.. :roll:
TJ
Post by TJ »
badnuz wrote:yeah that stuff is great i have done 5 or 6 cars with that stuff recently :) including my own even!
What about the outfit http://www.mobistint.co.nz? That was the original querry. Are they any good?
TJ
Post by TJ »
MudBum wrote:Hi guys, the law for a 4wd is W/S must be 70% (standard) front door glasses can only be 35% with 5% allowed on any other window.The strip across the front W/S can be a 100 mm but MUST follow the shape of the screen and not be put straight across from one side to the other. 8)
Straight windscreen in the front of a Wrangler!!! And no its not Jap import, NZ new.
Great advice guys, I think I'll stay away from 5 percent in the rear now. Interior lights I can turn down (dimmer on the dash already installed). So its just a matter of do I want to cut it myself and get the rolls or buy the pre-cut. Regarding life of it, well if I hate it enough being poor quality, I'll just spend a couple of days and take it off.
Trying to save money towards a good battery and then a winch.
tallsam66
Post by tallsam66 »
if the glass is flat & not curved...they can make just about any shape
1bad4x
Post by 1bad4x »
I just did my disco with 5% rear & 35% front & backing not a prob but I got a backing camera
& my van I put 5% on the front just waiting for Image at WOF time
it is easy to fit Image
My advice get the rolls so if you screw a window up no biggy :wink:
xj
Post by xj »
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
TJ
Post by TJ »
XJ, thanks for the photos. Looks nice and clean. You can do the same thing with soft top windows too. Just have to be a bit more careful.
The guy has sent me a photo with all the shades as how they would look for comparison. I think I'll get it in the next couple of days and experiment over the weekend.
xj
Post by xj »
i think ill hold out until next winter and get a new soft top with them already tinted.... or bite the bullet and get a 2 piece hard top with half doors (thought that may just get a weeeeeeeeee bit pricey!!)
ahhhh dreams, i remember as a young fella i had dreams.... fuk knows what happened to em.....
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
TJ
Post by TJ »
xj wrote:i think ill hold out until next winter and get a new soft top with them already tinted.... or bite the bullet and get a 2 piece hard top with half doors (thought that may just get a weeeeeeeeee bit pricey!!)
or to the young fella :roll:
Seriously though, if I do decide to get a soft top, I am getting the tinted window version myself. Then I look at the weather outside and say to myself whats the point....
Thanks for all the advice though.
Taz
Post by Taz »
I tinted the back windows in the safari, can't remember what percentage, was the darkest I could get from repco and I wouldn't do it again. Its way to hard to see behind you at night when trying to reverse. I would struggle to see someone standing behind it even with the reverse and brake lights on, maybe I'm just blind though.
DieselBoy
Post by DieselBoy »
I asked him for 5% and he delivered :P
As for 5% on the rear, i had/have 5% on the shorty on all of the rear windows for privacy when sleeping in it and keeping the band gear hidden when parked in town outside a gig.
Does that job nicely.
Reversing in the dark as mention is tricky. I mounted a 100w high level reverse light and it solved that problem.
I've put 5% on all the windows except the front two windows on the 80 series from mobistint. For what ever reason, its not that bad to reverse in the dark, but it's got a ladder on the back door, so will be getting the high level reverse light as well.
Was gonna get 5% on the front two windows ( you can legally if you have a fire arms licence) but pleased i didn't, the 25% are almost to dark :shock:
I recon that the kit is good value, the missus tinted her little 2dr GTI Pulsar which cost her a total of $200 in a couple of roles of tint and a few stuff ups while cutting.
Cutting the shape of the window is a tricky painstaking job. I hate it. Having pre cuts is the shit, you just lube it up and jam it on :D :D
Return to “Product Reviews / 4wd Service”
