What to look out for when buying a pto winch?
As i have a 70 series pto unit on the t-case i am after the drum, shaft and lever, i have been offered a 60 or 70 series setup which would work better on the 40?
Buying a pto winch
Buying a pto winch
microwaved cheese on toast
you will need to shorten the shaft to make it fit, I got a 60 one and had it done, I think that the 60 has two mounts mid shaft where the 70 only has one, (could be wrong, it happens from time to time
Toyota can still get parts ex japan, bit of a wait but the stuff I got was cheep as.
good luck with the mod
the drum is the same on either model the only difference is the driveshaft,you shouldn,t have to much of a problem .u need to measure from the output flange on your pto unit to the front of the chassis crossmember below your headlight panel.because you are 5 speed you will need a slightly longer shaft .hopefully either 60 or 70 series will work .easy enough to shorten
heres a cheap pto jumper .i,m sure one of the ore boys in chch could help get it up http://www.trademe.co.nz/Browse/Listing ... =126327960
