Replacement Ring and pinion
BJ71
Post by BJ71 »
I am after a replacement crown wheel and pinion for a 94 Prado rear (with E-locker) 4.3 ratio.
i believe they are the same gear set as the heavier hilux turbo/v6 diffs.
does anybody know who in NZ or Oz can supply the gear sets at a resonable price, NOTE Toyota isn't one of them.
or if anyone has a none locker centre available i dont mind swaping the gear sets over.
Thanks
Tony
Jafa
Post by Jafa »
Cant help with 4.3, but I'll have some 4.88's and some 5.29's for the V6 carrier soon
021 273 9942
jafa@inspire.net.nz
wjw
Post by wjw »
I have a set of 4.3's out of my Prado sitting on a shelf down at 4wd accessories... they've done 140,000k's and are in good nick.
interested?
Who knew Prados could fly?
BJ71
Post by BJ71 »
Probably, name your price?
wjw
Post by wjw »
$100 each... ??
spanky
Post by spanky »
SLIGHTLY OFF SUBJECT BUT WILL THE V6 DIFF HEAD STILL GO IN A SOLID FRONT END.CHEERS
VAUGHAN
BJ71
Post by BJ71 »
yes.
follow this link for some good info
http://home.4x4wire.com/erik/diffs/#rear
spanky
Post by spanky »
cheers for that, now i can put the 4.88 4 pinion lsd in the front and weld the rear one. cheers
vaughan
Clint
Post by Clint »
South Is Bearing supplies was recommended to me when I was pricing up 4.88's, they had a decent price IIRC. The wrecker in Rotorua is selling new hilux/prado R&p's for $250, I'd guess they'd have 4.3s.
Clint
UZJ71 Landcruiser
KTM 640
IcedJohnno
Trailer Trash
Post by IcedJohnno »
See my other post about this
http://www.offroadexpress.co.nz/modules ... highlight=
Try Craig at South Island Bearing Distributors Ltd
cnr Kingsley & Brisbane Sts Sydenham Christchurch
0-3-377 3222
not sure about 5.29's but he has definately had Toyo Cw & P's
Good quality ones from Italy, been well tested in rally cars too.
Cheers john
Mattman
Post by Mattman »
Is that new 4.88 R&P's for $250 Clint?
Is the Prado front high pinion physically the same?
Matt.
wjw
Post by wjw »
Or you could try Jafa ;-) he has new R&P's
Clint
Post by Clint »
Mattman wrote:Is that new 4.88 R&P's for $250 Clint?
Matt.
Yep, I got a couple of prices around the $250 mark for new 4.88s
I haven't had the front chunk out to be sure but legend has it that it is the same apart from being 2-spider rather than 4 like the back & possibly a different spline on the sidegears.
Clint
UZJ71 Landcruiser
KTM 640
wjw
Post by wjw »
Front is a 8" reverse high pinion. Two Spider
Return to “Toyota”
