yorick wrote:Anchor me, Anchor You.
If you're into serious recovery then these things are essential. If you were doing a hard core Solo or two wagon trip then these are for you. The ones in the drawing are smaller than what we used but no matter, the weights aren't the same either. I've on;y drawn in ten holes, however you can put as many or as few as you like depending on your needs ie LJ Zook or MobyToyota
These are designed to be made out of 8 or 10mm steel plate. The thickness is critical mainly for the end holes cos they're the ones that take the real load. Overkill is good. Everything should break before your anchor plate.
The holes are about 25 to 30 mm. Stakes are up to the designer, however I liked High tensile Hexagonal Rod, purpose built extractor
Only steady winch pulls.
Yorick, I clipped out heaps in the interest of readability.
However, if EVERYBODY made and had just one with stakes, at Pureora there woulda been HEAPS for a decent recovery.
The design has a certain beauty, the dont have to be uniform, as big or little as the maker likes. there is only ONE constraint, the end profile so it can allow the attachment of subsequent plates.
The plate only needs to be made of mild steel if the end hole is reinforced.
Even the rods can be made to the owners space restrictions.
Still need a heavy dong-beater to drive em into the ground!!
