Calling all Engineering types.....
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
NJV6
Post by NJV6 »
Rated to 110km/h
P.S., read the 4th reply regarding rated paper clips
hi guys. pm was from me and had been searching for a while but i counldn't find a topic with an 84 solid axle surf on it. it seems all the later model ones came out with factory hooks and people just took them off and used the holes again. but i cant see any factory hook mountings on mine. sorry jerry
PM Coxsy or 4wdbits (they are jaffa's too :lol: ) they can have a look at your setup and help...might cost you some lion red though :lol:
I seriously doubt that......the cheaper ones are likely to break and we all know you will get a paper clip in the back of your head.....have they got a rating mark on them?
xj
Post by xj »
gimmemud wrote:hi guys. pm was from me and had been searching for a while but i counldn't find a topic with an 84 solid axle surf on it. it seems all the later model ones came out with factory hooks and people just took them off and used the holes again. but i cant see any factory hook mountings on mine. sorry jerry
See Rex, told you it wasnt 86Surf!!
Back to the paperclips, for those with chain driven cams..... link the paperclips (non-plasticised ones, the plastic will melt and cause lumps on the cam) and fit in place, cheap and easy!!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Steve_t647
Post by Steve_t647 »
If you get a flat tyre grab 3 or 4 of them straighten them let out the air and put them down the side of the tyre to leaver over the bead. Leave the first one in place and use another about 5 cm away.
Work around the tyre until it is off.
spanky
Post by spanky »
last time out at ngaroma when i blew my diff my mate had some paper clips in the tool box and put all the broken spider gears back together and made a daisy chain around the carrier and fixed the problem, i think it is a auto locker even now :D .
vaughan
Your going to the BBQ apparantly? coxsy said he would have a look and give you some advice/help etc...
Better thank all the other guys for their excellent paper clip tech :roll:
NJV6
Post by NJV6 »
Just get various paper clips and they'll wip a rated paper clip hook up for you on site at the BBQ.
But as mentioned DO NOT get a plastic coated one or a bulldog clip, - they do not withstand 90km/h snatches, that the chrome ones will.
Return to “4wd Safety”
