fish wrote:cheers, i have the wheele off, and theres 6 bolts is that what you take off?
if so i dont have anything to get em off my sokets are too big and spanners no good.
while under there i noticed that the rubber boot on the cv is split and leaking grease, its a big hole....
is that hard to do? im cosidering just getting someone to do both jobs at once for me
any thoughts?
Those instructions are good, but your reply has me worried - maybe you should take it in to get done
...or do you know someone who's mechanically minded that can help out? If you pull it all down but you're not sure what you're doing then you may end up with it undriveable and having to call a mechanic out to your place.
Remember this is wheel bearings and driveline related - if it goes wrong then you could loose a wheel or worse.
I'm not trying to scare you, it is a relatively simple procedure, but if you are not confident, then get some help. Maybe even ask a garage if you can watch and learn while its done... Its a shame the 2 people I could have recommended to help you down there are not there any more... Conan has gone to Aussie apparently and Bill (WJW) is up here now.
Good luck with it
Steve
