petefj40 wrote:Tuning the LS1 ecu, "in real time"![]()
I'm real excited about this latest mod. It's still in the planning stage.
But in short. The reason for the mod is simple. I want to be able change a power curve on my own and do it "in real time" on both my V8's. (LS1 5.7L FJ40/Holden VX which has the LS2 6L but is controlled by a LS1ecu)
I'm fairly happy with the FJ40's tune but not at all happy with the Holden's tune. Spent heaps of coin trying to get it right.
Well fark me, I got told about a package today that allows you tune things on the fly called "Roadrunner". How it works is. The system is grafted onto the PCM's main circuit board in place of the original flash ROM.![]()
Just check out this link below.
I'm buzzing about this...![]()
http://www.gmhightechperformance.com/te ... index.html
Hmmmm
I used to run an engine brake in the UK for a while and have spent a lot of time round a very good hydraulic pod dyno at P.A.D. Racing here in Chch.
With late model engines there are many variables Pete. It is really easy to change things for the worse. It might be just difficulty with cold starting or as drastic as advanced knocking or melting pistons.
I learnt the hard way, the first time I modified a road engine at 18. Only the heady technological heights of a 1700cc Ford Kent engine too, so not complex in any way. Only revving to 8k.
Higher compression ratios = more airflow. Re-jet the carb or you will melt pistons! Only took a 50km blast too
My suggestion is to go to an expert who you can trust. Not all so-called experts have good analytical skills nor know when to ask for advice. Garry at P.A.D. is dyno-ing most days of the week and you will find the engines he tunes win most classes, whether off-road, classic, speedway or F5000 racing. His results speak for his skill and quality.
Compare the price of a quality dyno tune to an LS2 engine rebuild. You know the answer.
