GQ project.
Re: GQ project.
Once your hood pins go all rusty, buy some stainless 12mm bolts from Bunnings and cut the head off to replace. Same size, fit the same way but don't rust!!!!
- flyingbrick
Re: GQ project.
dammit, im sure i wrote out a big post and it flippin disappeared.
Got two of these sets
for $22 per set with FREE SHIPPING which cant be beat- its just not worth starting from scratch and trying to find the cable, clips, making the pins and the rings.. Hopefully they don't rust through the chrome too quickly
and good idea on the bolts.
Will post some pics tonight possibly. I'm off to the profile cutters to get some stuff made.
-Nathan
-Nathan
- flyingbrick
Re: GQ project.
I decided fairly early on that I was taking a completely minimalist approach to the interior. I want things to be as clutter free as possible to aid with things like cleaning, maintenance, weight and coooooool factor.
So- The things not going to have a dashboard.
. This big ugly piece of pipe has gone
and i made this yesterday to go in its place.
Today i borrowed a mates air compressor (thanks pal... but my fcuk is it useless at running air tools) and cleaned off all the unused brackets and tabs
And yes there are a few holes there that need welding up
I then had a sit in the truck with the bar in place and realized that it was a little too low and too far back- the bracket going down and forwards to the steering column was going to end up being pretty damn ugly- so new brackets were drawn up and will be taken to the profile cutter on monday once he is back at work. I just cant be bothered making them again,
I'll then sit it in place and with my gauges mark out where everythings going to go. I have 50mm water temp and oil pressure, 60mm EGT and 80mm boost gauges on the way.
The pipe will then be scalloped around half way through so that the gauge cups sit down in the pipe pointing at the driver like they are supposed to be there.
I also went over the engine bay with the air chisel (which is now my all time most favorite air tool) and used it to remove all of the annoying plastic clips and zipties that were still in there as well as a whole lot of sealant and crap. Air chisels are AWEEEEESOME at removing factory tar sound deadening material. It just blasts it off with bits exploding free in every direction. I wish i had more to remove
Re: GQ project.
i had all my fuses, relays, switches, gagues in a console between seats, brought a stork that did everything for lights, indicators, to get around the legalities of having to have a heater in the vehivle seeing it was a lux was to put a rear demister that goes on the windscreen, all up you can save maybe 50kg's, max
- flyingbrick
Re: GQ project.
thanks dude. I'm using the little rear heater box from the center console to provide some warmth and demisting. Don't think the lux has one on the rear window so i'll have to sus one out.... Although it is within wiping distance anyway
Where did you buy this generic stalk from? I've got the lux stuff there that i can use (just have to sit down with a multimeter and work out what all the pins do in the plug) but if there is an easier way im all for it.
Wipers ETC will be fine on a toggle switch.
Re: GQ project.
whats the reason behind not running a dash?
- flyingbrick
Re: GQ project.
I saw this car in a magazine quite a few years back (twin vr6 engined vw) and have always loved it. Gauges on a bar.
but yeah aside from that there are the other reasons mentioned above in a previous post.
i like simple.
Re: GQ project.
flyingbrick wrote:Alright so the cab was sitting on waynes truck until saturday. I'd heard we were gonna be there doing something and sat around home txting him and waiting for a txt back so I could get down there to help.
Suddenly he txts me and says "cabs coming off"![]()
Nice nipple.
and theeeeeen.. its back to waiting for wayne
jesus christ my workshops clean
should see it now bits of chassis and fail lux everywhere. ... i think all thats gunna be left will be the 2 rails and the diff's ... everything else has been binned lol ...
Kiwi4x4
- flyingbrick
Re: GQ project.
yeah bro. Saw what you were doing in there the other day. to say that i was impressed is an understatement.
BTW should be able to get most of the rest of my cool shit over the next two weeks. Glass guards, steel wheels, replacement doors, W2A IC, etc etc etc. Its all due to be collected/delivered etc and im EXCITED.
Paint is not going to stay all white. R/C stadium trucks of the 90's are my inspiration.
. Now trying to crank some favors out of people I know for a place to spray
-Nathan
-Nathan
Re: GQ project.
Re: GQ project.
Shouldnt that dash bar be part of your internal rollcage Nathan
- flyingbrick
Re: GQ project.
thanks guys. Man an internal cage would be rad. An exo would be even cooler.
the sad fact is that i simply will not have room i there for an internal one as far as width etc goes because of the tunnel. I'm sure I'll be able to heat up and bash in some of the tunnel to give more seat room but there is not realy all that much clearance between trans and sheet metal for this to happen.
Helping vvega atm at the workshop. I'm about to grind the shit out of hi chassis and then attack it with the air chisel. I'm looking forwards to that part.
In terms of paint sceme im tinking more along the lines of two tone... white and fluroescent orange or maybe fluro green/yellow. Orange bottom fading into the white upper half. No sharp edges. Retro as shit. Cabs already white and fairly nice so all i have to spray on is the other color.
Had some nice presents waiting for me at the parents when i went to visit on fri. autogauge gauges and some temp sendor adaptors. so cool
-Nathan
ps. I shot the shit out of a pair of glocks today. Fcuking cool.
-Nathan
- flyingbrick
Re: GQ project.
And because i love pics.
Re: GQ project.
Hey Nathan you got the cab on that GQ yet.? Or are you still busy helping that mad Wayne with his creation
Re: GQ project.
How are you going to get of with the internal projection rules with no dash when you come to cert it? I thought long and hard about leaving mine out but canned it to make it easier to certify.
(I assume it is staying on the road)
- flyingbrick
Re: GQ project.
The bar is very far away from the drivers and passengers and well out of the way. I'll wrap it in foam noodle infront of the passenger.
It makes the interior so spacious
And yeah helping wayne. been here (im at waynes right now) helping the last 3 nights. like 5 hours a night
- flyingbrick
Re: GQ project.
hahahahahahahahhaa.
Tomorrow- assuming I get paid (didn't get a pay slip today
so wondering WTF) im bringing food. I cant do shit without eating straight after work.
- skid
- Tyre Man
Re: GQ project.
vvega wrote:didnt see you tonight ... so hope all is well mate
probably out chasing good wholesome christian girls
or maybe asleep, unlike the rest of us
- flyingbrick
Re: GQ project.
Majorly needed an early night and don't have your cell number
Keen for a few hours tonight or you getting the girl back?
ps. got me a credit card bro so i can order some shit from over seas
Man im keen for some christian girl right now. /anything non fattie.
-Nathan.
-Nathan.
- Andrew1706
Re: GQ project.
Since you're staying with fat Safari diffs you should but my 38s
Then you would have the same clearance as a stock Hilux
- flyingbrick
Re: GQ project.
LOL!
I love it.
What are the tires? condition?
I love it.
Re: GQ project.
i'm thinking about these puppies to stroke my ego
http://www.trademe.co.nz/Browse/Listing ... =264939312
- Andrew1706
Re: GQ project.
15 minutes later lil.angel is straight in there
Heres mine: http://www.trademe.co.nz/Browse/Listing ... =265648936
- flyingbrick
Re: GQ project.
yeah not so keen sorry dude. Wanting tires a little more off road orientated. Not needing AT's
Re: GQ project.
Hows your progress or are you spending all your time working on Wayne's piece of jumk
- Andrew1706
Re: GQ project.
flyingbrick wrote:yeah not so keen sorry dude. Wanting tires a little more off road orientated. Not needing AT's
Good luck, seems you have a lot to learn
- flyingbrick
Re: GQ project.
didn't mean to offend. Just searched the shit out of google.
- flyingbrick
Re: GQ project.
Man... I want an X link.
