VVILLY TONKA-KZN185
basics
Re: VVILLY TONKA-KZN185
Post by basics »
you know were all waitin for videos in the mud once you have her certed :lol:
99 pajero exceed 3.2
kbjj
Post by kbjj »
Looking good... beadlocks aye, do they have the alloy outer ring? Who does them and how much? Did your rear bar fall off :lol: I assume it's still work in progress
vvilly
Post by vvilly »
Unfortunately they are ricks not mine, they on there for cert will be ordering them once I got other stuff sorted. They are alloy outer rings and the kit is around 250 a corner. Still working on it. Wasn't a requirement for cert so took it off. But when I get back from holiday I'll be finishing it :)
vvilly
Post by vvilly »
Got the truck home for the weekend to do some work on her before she goes back to Don for cert on wednesday. Noticed that the O/D light on the dash is flashing. What would be causing that?
taz01
Tazzles
Post by taz01 »
lack of use??????????? :lol: :lol:
WARNING:
vvilly
Post by vvilly »
:wink: thats a bit harsh :shock:
hosehustler
Post by hosehustler »
it's most likely a fault code, do a web search for fault codes for your model.
Is the speedo working? often O/D flashing is the speed sensor, also try disconnecting battery to reset computer, that works on some models
I hate signatures
vvilly
Post by vvilly »
yeah been looking on the net for a bit.
speedo working fine and reading true. The auto is running fine too
will disconnect the batteries tomorrow
The WEHI
Post by The WEHI »
Its a shame you dont know an auto transmission technician aye?
if you need a hand give me a bell,
ps text me again i reset my phone lol.
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
jonossiksilvia
Post by jonossiksilvia »
Your running a different auto on it arnt ya? Could.be something not hooked up. Best bet would be pull the codes and see. Take it its changing properly, enough fluid, feels like its driving properly?
vvilly
Post by vvilly »
Ii had a reconed trans fitted 1 week after buying the truck so we kept that and put the 130 transfercase behind it. Its running mint as. But as soon as you go over 50 km the light comes on.
vvilly
Post by vvilly »
thanks jordan for the help much appreciated O/D light sorted :)
The WEHI
Post by The WEHI »
Allgood bud ill have a look round see if i can find any info on the transfer to.
(027 788 1046)
bob_or_jim
Post by bob_or_jim »
Im in the process of wiring my LN130 trans and case for the same mods, any hints?
Big
Post by Big »
Interested in how cert goes..? as Im sort of holding off due to the authority card thing..?? might not have to.. but let us know how ya get on..nice build.. 8) cheers
vvilly
Post by vvilly »
bob_or_jim wrote:Im in the process of wiring my LN130 trans and case for the same mods, any hints?
We used the 185 a343 and the 130 TC plugs match up with a little bit of jossling as we found out today. The 130 tc speed sensor is on the opposite side compared to the 185 but all the rest of the loom was plug and play.
But we found another issue, that i was not aware of and i think rick wasnt either 4wd doesnt work for some reason.
vvilly
Post by vvilly »
Big wrote:Interested in how cert goes..? as Im sort of holding off due to the authority card thing..?? might not have to.. but let us know how ya get on..nice build.. 8) cheers
She goes in on Wednesday. Don has already had it in for the bump steer test. truck drives mint as. handles nice on the road it doesn't dive all over the show just a bit soft in the corners but other than that im happy
bob_or_jim
Yeah thats the bit im interested in (4wd) Ive compared the two and the plugs are the same although some of the pins appear to do different jobs. The 185 plug has 6 pins and the 130 only 5. Ive got a little bit of a diagram drawn up but im just trying to figure out what they all do.
Dont spose you have a 185 wiring diagram?
I was hoping to get everything to work off the factory button and have the lights on the dash work.
Anyway let me know how ya go.
jonossiksilvia
I have the transfer diagram for the 130 if u guys need it. I know with mine I needed to bridge the plug to the sensor that was on the old front diff to get mine working. May be same with you guys
bob_or_jim
Yeah that will need done as well I think. The problem is the 185 has a similar motor on the gearbox to activate 4wd but its controlled a little diff to the 130. Im sure getting it to go wont be hard but getting the lights to work properly maybe a little different. Do you have pic of the diagram?
The WEHI
Post by The WEHI »
Not going to tell these nice gentle people how you found 4wd didnt work? Haha
(027 788 1046)
SamLogan
Post by SamLogan »
if your 4wd is not working what i did was follow what guys in the states use to wire toyota diff lock motors up. There are diagrams to wire them up to a dpdt switch which is really easy. Just don't use the activation light setup they use. The motors, despite they look different, are all the same internally. I built one for a diff lock out of a 4wd activation one. Mine is currently an external switch. There is also plans to use a dpdt relay with an external switch so you can use an normal switch but i found with free wheeling hubs and the surf current setup that having a 4wd activation switch away from accidental knocking range is good. If you need be to show you Jason i am sure i can.
Sam
vvilly
Post by vvilly »
jammysammy wrote:if your 4wd is not working what i did was follow what guys in the states use to wire toyota diff lock motors up. There are diagrams to wire them up to a dpdt switch which is really easy. Just don't use the activation light setup they use. The motors, despite they look different, are all the same internally. I built one for a diff lock out of a 4wd activation one. Mine is currently an external switch. There is also plans to use a dpdt relay with an external switch so you can use an normal switch but i found with free wheeling hubs and the surf current setup that having a 4wd activation switch away from accidental knocking range is good. If you need be to show you Jason i am sure i can.
Sam
Pm'd
jonossiksilvia
bob_or_jim
Awesome, thanks for the diagrams.
vvilly, sorry about the thread jack.
vvilly
Post by vvilly »
bob_or_jim wrote:Awesome, thanks for the diagrams.
lol all good but im might get really angry and start putting ................ everywhere
vvilly
Post by vvilly »
Well very happy she passed cert today. Well kinda she has to go back on wednesday with mudflaps lol
jonossiksilvia
vvilly wrote:Well very happy she passed cert today. Well kinda she has to go back on wednesday with mudflaps lol
i know that feeling lol same with mudflaps for me on second test :lol:
vvilly
Post by vvilly »
We were thinking other stuff but not mudflaps lol
The WEHI
Post by The WEHI »
Choice! whens the breathers and snorkel going on?
(027 788 1046)
