Proper rugged solid farkers, not some poser shit
Added some alloy tread plate for grip when getting in and out
DieselBoy wrote:
Anyone know what the manifolds are like?? Are they a good fit, nicely machined flange's etc etc
real nice. I had one corner of the flange to grind off but otherwise perfect. Nice machining and cleaning up, equally sized ports and very nicely shaped runners all with a very similar ID and no nasty ridges or funny intersections.
excellent service too
DieselBoy wrote:...Added some alloy tread plate for grip when getting in and out
MNC wrote:DieselBoy wrote:...Added some alloy tread plate for grip when getting in and out
Nice work DB. I'm trying to make it out from the photo's - have you riveted the Ali checker plate on?
DieselBoy wrote:Its a whole lot of stuff based on the turbine and compressor blade trim A/R ratio's, as well as housing size's.
Apparently this particular turbo has desirable performance characteristics for the TD42.
This should be making max boost of 17psi at 2000rpm which is the engines sweet spot.
I will be dropping that to 8 or 10psi for reliability and to nurse the standard clutch for a bit.
Heath wrote:DieselBoy wrote:Its a whole lot of stuff based on the turbine and compressor blade trim A/R ratio's, as well as housing size's.
Okay cool. I guess outward appearances mean nothing with these things and its about the blade shapes, etc.
DieselBoy wrote:Keen for some dump pipe pic's Shane![]()
