Tomsoffroad & Customs
Vendors selling all suspension components from shackles to Shocks.
Moderator: Vendors
tomsoffroad
Flopsie
Re: Tomsoffroad & Customs
Post by tomsoffroad »
tomsoffroad
Flopsie
Mattman
Post by Mattman »
Lovely work Tom. Jealous......
De-Ranged
Post by De-Ranged »
whats the score on the tabs ontop of the lower mounts ..... another set of shocks or sway bar ?
tomsoffroad
Flopsie
De-Ranged wrote:whats the score on the tabs ontop of the lower mounts ..... another set of shocks or sway bar ?
Swaybar :wink:
suzolla
Post by suzolla »
Hi Tom,
Looking good, couple of questions
What bushes are you using
Are the top and bottom links the same length and are they parallel to each other.
Any touching of the Tie rod on the bottom links at full flex
whoops that was 3 questions
Tim
tomsoffroad
Flopsie
suzolla wrote:Hi Tom,
Tim
Bushes are 130 surf
top arms are 610mm. Lower arms are 700mm and aren't parallel.
No touching but at full flex and full lock there would only be 1mm clearance max.
Its all pretty tight in there Tim. I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
shortylux
Post by shortylux »
tomsoffroad wrote: I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
At least that is an easy(ish) thing to change in the future if it becomes an issue.
As always, nice work bro.
tomsoffroad
Flopsie
Thank you :D
There's no issue with this one bro. Just thinking out loud for the next one :wink:
suzolla
Post by suzolla »
Hi Tom,
Thanks for the info, looking to do mine sometime but will see if cert man will accept single top link.
Sounds like it is well designed if no touches, good stuff.
Tim
tomsoffroad
Flopsie
Tim
Was a mission Tim :lol: you shouldn't have any problems with a single top link, ive sent a few through cert now. Seems that as long as the top link is on the diff head theres no issues.
mike barnett
Post by mike barnett »
if that builder boy now with a bowtie uses that magnificent piece of engernering to out drive my nissan ill shout him a 24 pack and cook him breaky.hahahaha nice work tom turbo soooooon ??? or should i ask him :wink:
tomsoffroad
Flopsie
mike barnett wrote:if that builder boy now with a bowtie uses that magnificent piece of engernering to out drive my nissan ill shout him a 24 pack and cook him breaky.hahahaha nice work tom turbo soooooon ??? or should i ask him :wink:
Haa lets not go there Mike :mrgreen: :mrgreen:
Turbo is always a good idea :twisted: :twisted:
Nigel Bannan
Post by Nigel Bannan »
Time will tell Mike! You going to Westport with this lot? Nig
Twodiffs
Post by Twodiffs »
Off to Perth next month Nig...want me to bring you back a UFI jobbie? :wink:
tomsoffroad
Flopsie
Update time :mrgreen: Just finished Adams LN106 Tube(ish) deck.
It has a underdeck winch, Hi-lift and spade mounts and a under deck box for strops etc.
This is where we started
Winch mount (haven't added the actual winch mounts in this pic :roll: )
Whipped up some chunky guards
tomsoffroad
Flopsie
Then onto the cage :mrgreen:
Then add the pretty black paint......... job done :D
catalystracing
Post by catalystracing »
When I grow up I wanna be like Tom 8) :mrgreen:
The rear lights really set it off nicely
Super nice work mate :D
Mattman
Post by Mattman »
That is awesome. Looks like a wicked truck.
4X4LUX
Post by 4X4LUX »
:mrgreen:
tallsam66
Post by tallsam66 »
Thanks for ya help today :)
tomsoffroad
Flopsie
Another update........ another LN106 Hilux rears up front conversion with a kzn165 rear leaf swap. Oh and sliders :wink: :wink: Ended up with some pretty sweet flex for leaves :mrgreen: :mrgreen:
tomsoffroad
Flopsie
Then I got back onto the x brace on the Prado........ Before you ask :lol: ..... 1. Yes it unbolts. 2.The centre hole is above the radiator filler cap.
nztimr33
Post by nztimr33 »
looks sweet man 8) was wondering what u were going to do with that rather large hole in the bonnet :wink:
tomsoffroad
Flopsie
nztimr33 wrote:looks sweet man 8) was wondering what u were going to do with that rather large hole in the bonnet :wink:
Cheers :D I try to do things differently :mrgreen:
Petemcc
Post by Petemcc »
have you got the full leaf pack in the rear of that lux? Looks to be close to the bump stops. Mine is a bit short, was thinking of taking out one of the overloads but not sure which one.
Pete
tomsoffroad
Flopsie
Petemcc wrote:have you got the full leaf pack in the rear of that lux? Looks to be close to the bump stops. Mine is a bit short, was thinking of taking out one of the overloads but not sure which one.
Pete
yeah it is a full pack Pete. All the weight on the back probably helped :D
Petemcc
Post by Petemcc »
yea might have to try it with the fire wood on tomorrow haha.
Also have you got any pics of your front shackles? Do you put a support brace in them to stop them twisting like with the back ones?
tomsoffroad
Flopsie
Petemcc wrote:yea might have to try it with the fire wood on tomorrow haha.
No theres no barce in the front shackles. They're only 40mm longer than factory and there is no clearance for a brace.
Have yours twisted Pete? :? :D
KROOZA
Post by KROOZA »
That is pretty mean flex for leaves for sure !! Like it 8)
Return to “Suspension”
