Page 41 of 43
Re: Tomsoffroad & Customs
Posted: Tue Mar 18, 2014 8:32 pm
by tomsoffroad
Posted: Tue Mar 18, 2014 8:34 pm
by tomsoffroad
Posted: Wed Mar 19, 2014 6:35 pm
by Mattman
Lovely work Tom. Jealous......
Posted: Wed Mar 19, 2014 7:03 pm
by De-Ranged
whats the score on the tabs ontop of the lower mounts ..... another set of shocks or sway bar ?
Posted: Wed Mar 19, 2014 8:00 pm
by tomsoffroad
De-Ranged wrote:whats the score on the tabs ontop of the lower mounts ..... another set of shocks or sway bar ?
Swaybar
Posted: Wed Mar 19, 2014 8:46 pm
by suzolla
Hi Tom,
Looking good, couple of questions
What bushes are you using
Are the top and bottom links the same length and are they parallel to each other.
Any touching of the Tie rod on the bottom links at full flex
whoops that was 3 questions
Tim
Posted: Wed Mar 19, 2014 9:19 pm
by tomsoffroad
suzolla wrote:Hi Tom,
Tim
Bushes are 130 surf
top arms are 610mm. Lower arms are 700mm and aren't parallel.
No touching but at full flex and full lock there would only be 1mm clearance max.
Its all pretty tight in there Tim. I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
Posted: Wed Mar 19, 2014 9:23 pm
by shortylux
tomsoffroad wrote: I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
At least that is an easy(ish) thing to change in the future if it becomes an issue.
As always, nice work bro.
Posted: Thu Mar 20, 2014 7:00 am
by tomsoffroad
shortylux wrote:tomsoffroad wrote: I wondered several times if using prado knuckles and ln106 steering arms would've been easier. Then by setting up the tie rod and drag link like on a 60 series cruiser the tie rod would then be in front of the diff. Food for thought.
Thank you
There's no issue with this one bro. Just thinking out loud for the next one
Posted: Thu Mar 20, 2014 9:20 am
by suzolla
Hi Tom,
Thanks for the info, looking to do mine sometime but will see if cert man will accept single top link.
Sounds like it is well designed if no touches, good stuff.
Tim
Posted: Thu Mar 20, 2014 11:10 am
by tomsoffroad
Tim
Was a mission Tim
you shouldn't have any problems with a single top link, ive sent a few through cert now. Seems that as long as the top link is on the diff head theres no issues.
Posted: Thu Mar 20, 2014 7:56 pm
by mike barnett
if that builder boy now with a bowtie uses that magnificent piece of engernering to out drive my nissan ill shout him a 24 pack and cook him breaky.hahahaha nice work tom turbo soooooon ??? or should i ask him
Posted: Thu Mar 20, 2014 9:53 pm
by tomsoffroad
Posted: Fri Mar 21, 2014 7:10 pm
by Nigel Bannan
mike barnett wrote:if that builder boy now with a bowtie uses that magnificent piece of engernering to out drive my nissan ill shout him a 24 pack and cook him breaky.hahahaha nice work tom turbo soooooon ??? or should i ask him
Time will tell Mike! You going to Westport with this lot? Nig
Posted: Sat Mar 22, 2014 7:57 am
by Twodiffs
Off to Perth next month Nig...want me to bring you back a UFI jobbie?
Posted: Fri Mar 28, 2014 7:04 am
by tomsoffroad
Update time
Just finished Adams LN106 Tube(ish) deck.
It has a underdeck winch, Hi-lift and spade mounts and a under deck box for strops etc.
This is where we started
Winch mount (haven't added the actual winch mounts in this pic
Whipped up some chunky guards
Posted: Fri Mar 28, 2014 7:07 am
by tomsoffroad
Posted: Fri Mar 28, 2014 7:20 am
by catalystracing
When I grow up I wanna be like Tom
The rear lights really set it off nicely
Super nice work mate
Posted: Fri Mar 28, 2014 7:59 am
by Mattman
That is awesome. Looks like a wicked truck.
Posted: Fri Mar 28, 2014 7:36 pm
by 4X4LUX
Posted: Sat Mar 29, 2014 4:05 pm
by tallsam66
Thanks for ya help today
Posted: Fri Apr 04, 2014 7:22 pm
by tomsoffroad
Posted: Fri Apr 04, 2014 7:35 pm
by tomsoffroad
Posted: Fri Apr 04, 2014 7:38 pm
by nztimr33
looks sweet man
was wondering what u were going to do with that rather large hole in the bonnet
Posted: Fri Apr 04, 2014 7:59 pm
by tomsoffroad
nztimr33 wrote:looks sweet man
I try to do things differently
Posted: Fri Apr 04, 2014 8:54 pm
by Petemcc
have you got the full leaf pack in the rear of that lux? Looks to be close to the bump stops. Mine is a bit short, was thinking of taking out one of the overloads but not sure which one.
Pete
Posted: Fri Apr 04, 2014 9:27 pm
by tomsoffroad
Petemcc wrote:have you got the full leaf pack in the rear of that lux? Looks to be close to the bump stops. Mine is a bit short, was thinking of taking out one of the overloads but not sure which one.
Pete
yeah it is a full pack Pete. All the weight on the back probably helped
Posted: Fri Apr 04, 2014 9:45 pm
by Petemcc
yea might have to try it with the fire wood on tomorrow haha.
Also have you got any pics of your front shackles? Do you put a support brace in them to stop them twisting like with the back ones?
Posted: Sat Apr 05, 2014 6:37 am
by tomsoffroad
Petemcc wrote:yea might have to try it with the fire wood on tomorrow haha.
No theres no barce in the front shackles. They're only 40mm longer than factory and there is no clearance for a brace.
Have yours twisted Pete?
Posted: Sat Apr 05, 2014 7:31 pm
by KROOZA
That is pretty mean flex for leaves for sure !! Like it
