Page 43 of 43
Re: "bulletproofs" hilux specs and Videos
Posted: Tue Feb 26, 2013 9:51 pm
by slognad
Hi Richard
I'm not sure if you mentioned it in your last 80+ pages, I'm only up to page 35 atm, but when you changed your gear box, which one did you put in and did you find any problems with it?
Duncan
Posted: Wed Feb 27, 2013 7:21 am
by Bulletproof
slognad wrote:Hi Richard
Duncan
Hi Duncan
I am not too sure of the model number. But I believe it to be a G52 . It is the heavy box fro a surf and has never given any troubles.
Cheers Richard
Posted: Wed Feb 27, 2013 3:03 pm
by slognad
did it just bolt up? or did you have to change the crossmember?
Posted: Wed Feb 27, 2013 6:12 pm
by Bulletproof
slognad wrote:did it just bolt up? or did you have to change the crossmember?
It just bolted up. Because I run an after market heavy clutch I had to grind some of the strengthening rib off the inside of the bell housing to stop it hitting.
Cheers Richard
Posted: Fri Dec 20, 2013 1:18 pm
by Bulletproof
3 days of preparation for Xmas this year at Reefton completed apart from fitting the Simex's
Replaced the rear crankshaft oil seal
Replaced the clutch with a new Xtreme outback
Strengthened the side bar
engine oil and filter changed
Just need some good weather now
Cheers Richard
Posted: Fri Dec 20, 2013 4:08 pm
by imsohi
Fun times ahead we looking at heading to seddonville after christmas.
Posted: Mon Dec 30, 2013 11:15 am
by Bulletproof
Back home from Reefton with a faulty L/H rear brake.
click on the video why. Bent rear axle
Cheers Richard
Posted: Mon Dec 30, 2013 11:34 am
by SMOKEY
Should have taken the Land Rover,
THEY DON'T MAKE EM LIKE THEY USED TO,
FITZY.
Posted: Mon Dec 30, 2013 12:49 pm
by Big
it almost looks like it has worn on 1 side more then other too.. Must have taken a big knock to put that out of alignment..lol
Posted: Mon Dec 30, 2013 7:35 pm
by Bulletproof
First time I have broken a tail light since I built protection about 15 years ago.
It happened at the bottom of Trev's hill when I didn't make it and it ran back onto a piece of wood. So I have had a good run
Video clip
So my Xmas damage bill is starting to add up. Broken windscreen, Bent rear axle and a tail light plus disc brake pads from the bent axle.
Cheers Richard
