4 link not quite right
Re: 4 link not quite right
lol would go awsome with a turbo not that it doesnt go good as it is but everyone needs more power.
Goes better now the Crank angle sensor isn't all sloppy. But yeah needs more. But will be supercharged not turboed.
(just have to convince the minister of finance and entertainment.)
Back on topic have you got the flex where you want it?? Talk to you Sat
yep have got the flex right where i want it, in fact proberly more than i need but my limiting factor will be the shocks now. pic of the flex with chassis flat and the rear fully flexed the other wheel is just about to come off the ground. i get one wheel 700mm off the ground while other is 0mm off ground.diff is still pointing at t case output just might need a limiting strap to stop the diff from going too far down and stuffing up the angle but thats no problem. i will have a bit of rear steer when at full flex but i dont mind that as you very rarly have it on full flex.well anyways heres the pic
well tacked everything and took some pics, didnt lift it to full flex as its all tacked in and didnt want things to let go at a great hight.
they are vitara springs. new need to get the front done.
