project roadkill!!(nearly finished,yeah right!!)
Re: project roadkill!!(nearly finished,yeah right!!)
fitted locker, bearings and new brakes tonight....just got to get my drums tommorow from the machine shop and bleed the brakes, then rear end ready for play
time for an update.....since the last update i have blown my motor
so its been at the mechanics for a week or so and i got it home tonight with a new motor, its a g16b block from a cultas with the head, injection and loom etc from a g16a from a vitara and it runs smooth as
now all i need to do is: get a surge tank, fit new pumps(i have a low pressure one just need a high pressure one)wire in a thermo switch for new electric fan. make new bonnet catch as i had to cut old one out to mount new radiator from an old datsun with honda fan mounted to it and remake snorkle and air box etc
so all you have to do is everything?
made the new air intake for the injection today.....may look a bit hory but i didnt wana cut my snorkle again
gutted photobucket cuts the pictures
- moonhopper
hey Ryan looks bloody good to me, did the dizzy come standard like that, as the 413 leans the other way its a bit tall for my bonnet .i need one that leans the same way as the one in your pic, cheers
dizzy is from the vitara that i got the injection,loom,cam etc from
- moonhopper
does it bolt to the same mounts as the 413? as in the 1300 motor
its not photobucket that cuts the pics, its the new forum. to view the full size right click and click view image.
moonhoper wrote:does it bolt to the same mounts as the 413?
i dont know? but probly not as its the 1600 with the 16valve head.....
