GQTROL wrote:To me, the numbers are the point, so I give a f3ck. Someone said they've got 970Nm from their 6cyl 4.2 cruiser motor...I wanna see it, because unless they're running compound turbos and are getting 500HP etc, I'd say they've made a mistake with their calcs.
the thread is aimed at the viable option of fumigation in diesel engines not wether the dyno results are correct or not, they well may be wrong!! and really i dont give a flying rats cock if they are as its just a good way to measure the gains, i cant remember exact numbers but the original dyno run was about 65kw and 350nm?? then the second run was 120?kw and 970?nm so the outcome was very good gains.
you can piss and moan all you like but untill i can get the dyno sheets there is no evidence other than driving the bloody thing to your house laying a big fat skid on your driveway and towing your house down the road... with the LPG ON!!!
if the trans diddnt blow up
(not getting nasty, just an example...and no im not going to do it to my own house
the vehicle was run on the dyno prior to having an overhaul, turbo mod, pump mod, intercooler etc then dyno again after this was done to see the benefits gained, same dyno, same guy, same settings. it has not had its 3rd dyno run yet with the fume kit installed (
http://www.dieselgasaustralia.com.au ) as the trans has issues with slippage and needs to be nursed for a while ( too much grunt for the standard trans, oops
) when the trans has had its make over it will go over the same dyno again to see the results. but the drive test which so far is around 6000km towing a bloody great offroad camper all around the south island and some of the north with the gas on is fairly conclusive that it does actually work and fairly well to.
now can we get back to the actual topic please???
fume f&king works!!!
jeeeeezzzzeeeeeeuuuuuzzzzzz
