"Jafa's Jalopy"...3RZ-FE and on 40's:)
Jafa
Post by Jafa »
Ok Steve, here ya go :lol:
chopsawed the ends off my brand new shocks :shock: Then made up a collet to hold the chrome shaft so I dont damage it in the lathe chuck , then threaded the end and turned a little shoulder for the mount to screw up against.
Then chucked the billet of ally in the lathe and turned up the bottom spring mounts, they still have to get milled yet and a spherical bearing fitted
More on Monday night :lol:
021 273 9942
jafa@inspire.net.nz
timotheus
Post by timotheus »
Jafa wrote:it took 30 tons to make the housing move .2 of a millimeter, basically that means its fawkin strong
I was thinking more like insane.
I genuinely look forward to reading this thread, better than TV.
suzolla
Post by suzolla »
Hi, I like the look of the start of your coillovers.
Just a question on your front arm arrangement, are you going ot run a panard, or are you relying on the angled top arms to hold the front axle in the transverse position.
Thanks Tim
SupraLux
Complete Bastard
Post by SupraLux »
Front and rear are triangulated - running a panhard rod with this setup would just cause it to bind and make for less travel and more stress on the links and chassis...
This truck should just about be able to get 90* between axles at full flex - once its finished it should get the best RTI score of the year for 2014 of any truck I've seen in NZ.. :) (I should really lay off the slow-build jokes - I'm not a speedy builder myself :P)
Steve
rokhound
Post by rokhound »
I hate you Jafa! :wink:
No one should be allowed access to all the cool plant that you have :lol:
(insert big green envy monster here)
suzolla
Post by suzolla »
Thats why I asked the question Steve, problem I see with triangulated is that with a std steering box and drag link and a lot of travel, will get bump steer, so was just wondering.
Tim
SupraLux
Complete Bastard
Post by SupraLux »
The bump-steer should be as minimal as it can be with this setup due to the really long links... so road-going bump-steer should be fairly minimal... unless they are really big bumps :) However I don't think bump-steer is a major design consideration in this truck... its all about stupid-crazy-huge flex and showing off all his cool workshop toys :P
Steve
Jafa
Post by Jafa »
rokhound wrote:I hate you Jafa! :wink:
Some more CNC porn for ya Rok :lol: :lol:
Yes it will bump steer, but I'll get over that when I get it mobile. You've been reading on Pirate to much Suzolla :lol: :lol: :lol:
Bottom mounts milled up, spherical bearing installed
021 273 9942
jafa@inspire.net.nz
rokhound
Post by rokhound »
Ars* hole :lol: :lol: :lol:
turoa
Pyro Junior
Post by turoa »
rokhound wrote:Ars* hole :lol: :lol: :lol:
I beleive the correct terminology is "F#cktard"
paule
Post by paule »
bUGGER ME, THAT MADE A GOOD READ FOR PAST HOUR OR SO. IT IS SO COOOL. I WANT 1.
Engineer
Post by Engineer »
ohh cnc mill, ive only used one afew times :cry: altho i did make a cool wee thing with three cubes inside each other :oops:
Looking great!! Very jealous
Jafa
Post by Jafa »
Been busy as fawk wit work over the last couple of weeks, but I managed to get my coilovers done 8) cant wait to try these bastards out :lol: :lol:
Heres the slider bit that goes between the coils, slides up an down the shock body, made of UHMWPE (Ultra High Molecular Weight Polyethelene 8) :shock: ) in other words "tuff plastic"
This one shows the various bits, the threaded sleeve is pressed onto the shock body, took 10 tons to get it on, so I don't think it'll move. thought I was gonna fawk the shock when the pressure was going up :eek:
One more of the bits
The finished article
930mm extended, with 400mm of travel (bout 15 inches)
021 273 9942
jafa@inspire.net.nz
ELEV8
Post by ELEV8 »
wow! that is impressive. look better than bought ones.
Mattman
Post by Mattman »
Wicked.
That was quite a lot of pressure on the shock!
Matt.
Jafa
Post by Jafa »
Mattman wrote:Wicked.
Matt.
Yer, I was worried :lol: the shock body itself was miles out of round (nearly .5mm) which wasnt helping, it was tryin to "form" the shock body as well as press it on, worked out ok in the end tho. :D
021 273 9942
jafa@inspire.net.nz
Steve_t647
Post by Steve_t647 »
Serves you right for cheating! Next time you will make the shocks as well :lol:
Actualy you probibly already were thinking of that. Nice work have you come up with a plan for oiling in the PTO? or is that a later thing?
Engineer
Post by Engineer »
is that a lufkin tape measure?
Nice very nice by the way :wink:
Ryan
Heath
Post by Heath »
I dont know if it is the tech side of this build or the sexy machines with all that cutting lube spalshing around that ... oh shit gotta go.
Nice work Like watching a "craftsman at work".
Heath
Jafa
Post by Jafa »
Bit o "workshop flex" for the boys :lol: :lol:
021 273 9942
jafa@inspire.net.nz
wopass
Post by wopass »
kewl :D
niblik
Post by niblik »
thats some serious engineering and mods which = some hell sweet flex jafa... keep the posts comin, and hurry up and bring her down for a play guy... :wink:
Mattman
Post by Mattman »
That's going to look sick under a Lux with a Lexus in it!
Matt.
Steve_t647
Looks good apart from the shocks on the back what other suspension work is there? Or are you ready to start the drive line (PTO etc) and wireing the link or Lexus comp.
What computer do you plan on running? Are you going to make your own strengthened driveshafts? What Joints are you thinking of using having rotated the diffs?
Or like Steves thread keep watching, and go out into the Garage and do something yourself :oops:
Oh for the pirate you could have flexed the back in the opposite direction ;) Next time maybe.
Smurf
Post by Smurf »
Steve_t647 wrote:Looks good apart from the shocks on the back what other suspension work is there? Or are you ready to start the drive line (PTO etc) and wireing the link or Lexus comp.
It does sound like you need a project. :D :D
Jafa
Post by Jafa »
Holy Shit Steve :shock: :lol:
Wots wrong with the shocks at the back? Is it the fact theres only one?
Next is driveline,pto etc, still saving for the $1100 bux worth of alloy plate :shock:
Standard lexus comp
New d-shafts, using clearanced Carden joints
021 273 9942
jafa@inspire.net.nz
Steve_t647
Jafa wrote:Holy Shit Steve :shock: :lol:
Standard lexus comp
Thats what was missing at the back! Something didn't look right was all and I thought if the back was flexed out I would be able to pick it :) I want to see what the driveshafts look like with the PTO bolted up it will be quite a long gearbox assy.
I think I better hide out in my garage for a bit :lol: Maybe that way I could get something happening on it, still need some spending money to get your Hysteer, once i get the budget sorted. :oops:
Cant help with more hours in a day for you tho.
rokhound
Re: 5M Hilux - then 7M - Now 1UZ-FE...
Post by rokhound »
BUMP!
I think it must be time for another installment here Jafa. What does everyone else think? :wink: :wink: :wink:
Jafa
Post by Jafa »
Easy Tiger!! :mrgreen: :mrgreen: Basically I'm trying to source a block of alloy for the TF case/PTO case thingy from China for a third of the price of getting it locally. I have a man in China sorting it, but with Chinese new yaer and the language problems, its not easy :roll:
I've been fawking around with my Zook after squashing it as well, thats sucked hilux time too. I at the stage where I need to get the adapter done to get the driveline in, then it goes like this
1- adapter and driveline in
2- Cab on
3- sort headers and exhaust, fuel cell, get it running
4- make new trans tunnel
5- hotrod winch and attach it to chassis
6- Finish cage, and make deck, exo, and front bumper
7- sort out rear mounted alt,pwr steer pump and OBA
8- front d-shaft, and assemble front axle
9- rear axle
10-fit out cab
11-paint....finished...... :roll: :roll: :roll:
021 273 9942
jafa@inspire.net.nz
rokhound
Post by rokhound »
awesome. So it should be done when i have my new place built :wink: :mrgreen: :mrgreen: :mrgreen:
That has taken 4 years through planning, redesign, council etc :lol: :lol: :lol:
Is it not worth casting a new block of alloy and machining from there Jafa?
