"Jafa's Jalopy"...3RZ-FE and on 40's:)
Jafa
Re: 5M Hilux - then 7M - Now 1UZ-FE...
Post by Jafa »
Upon reflection, it may well have been, but I'm down the road now, so I'll carry on, once I get the chunk from China, itll still be cheaper than casting, its just the 'hassle' factor thats all
021 273 9942
jafa@inspire.net.nz
Engineer
Post by Engineer »
any progress jafa?
Ryan.
Jafa
Post by Jafa »
nope :roll:
021 273 9942
jafa@inspire.net.nz
Engineer
Post by Engineer »
how bigga bit of aluminium did you need?
Jafa
Post by Jafa »
2 bits, 1 @ 440 x 300 x 75, and 1 @ 440 x 300x 100 :shock:
021 273 9942
jafa@inspire.net.nz
Jafa
Post by Jafa »
Ok time for a bit of an update :oops:
Well I've changed direction yet again! :lol: :lol: :lol: :shock: Now instead of this being a road legal winch challenge truck, shes gonna be a trailer queen rock crawler only. Upon reflection, I think mine will be too heavy, too high and not built "specific" enough to be a good winch truck. I have other plans in that area! :mrgreen:
To assist me in getting it finished, its booked on the ferry to go to Christchurch for Rockrash 09 at Xmas!! :shock: so I've got 6 months to get it done! :mrgreen: Shouldnt be too much problem now that its not going to be road legal........ :?
I've actually done some work on it this weekend too, so were away!
Built a coupler to join the Hilux geardrive transfer to Lexus auto
Step on the front is where the speed sensor trigger goes
Seal prevents ATF and gearbox oil from mixing together
O Yeah and a set of 39.5 x 13.5 Iroks will be on it also 8) 8) 8) 8)
And my block of 7075 aluminium has turned up
So plans now are no crazy PTO winch drive(on this truck....)but it will have tiptronic style gearbox management, dual reduction boxes with 2.28 in the front and 4.7's in the back, I'll remove my coilovers and replace them with Racerunner airshocks and probably go full hydro steering. No rear deck to speak of, just a toolbox,divetank and fuel cell, no dash really either, just the basics, bit of an exo to protect the cab, and thats about it, mite chuck the rad on the back too..
This is what we'll make out of the alloy as soon as the machining center is available
There's a few changes from this design, I've used a 23-23 spline coupler out of a chaindrive tf case and pressed it into a sleeve instead of making a 23-21spline coupler. I'll be using a 23 spline input shaft in the reduction case so it'll be 23 spline throughout
021 273 9942
jafa@inspire.net.nz
Engineer
Post by Engineer »
Awesome! :D
doddzee
Is Doddgee
Post by doddzee »
Nice choice of tyres ther Jafa! Id love a set of those.
MWB V8 Safari Ute
rokhound
Post by rokhound »
Come on jafa, are you serious?
Your'e just teasing eh? :wink: :lol: :lol: :lol: :lol:
De-Ranged
Post by De-Ranged »
:shock: Damm Jafa I heard a rumor about how much you spent on that block of alloy :lol: my A class is cheaper than that block!!.... why didn't ya just fab up the basic shape in steel and then biff it at the cnc
As I've said before very cool 8)
Cheers Reece
De Ranged Engineering
027 541 8794
Jafa
Post by Jafa »
De-Ranged wrote::shock: Damm Jafa I heard a rumor about how much you spent on that block of alloy :lol: my A class is cheaper than that block!!.... why didn't ya just fab up the basic shape in steel and then biff it at the cnc
Hey Reece, nah this bit as only $500 :shock: This is a prototype for casting some alloy ones for production, so we decided to make it from alloy, it will give us a better idea on machining time, and its much cooler! :lol: :lol:
021 273 9942
jafa@inspire.net.nz
De-Ranged
Post by De-Ranged »
Might have been the block for the PTO... and oh yea it is way cooller :lol: :lol:
Jafa
Post by Jafa »
Righto, we've all seen the pretty pictures from the cad system, now heres some pics of it turning into the real thing :lol:
A bit more CNC porn for ya :mrgreen:
Here we go then, no turning back now.....its only a $650 chunk of alloy :shock:
Drilling a big hole through it
Ist operation is done, this is the end that bolts to the back of the trans
More to come this weekend 8)
021 273 9942
jafa@inspire.net.nz
turoa
Pyro Junior
Post by turoa »
thats cool, nice work
haynzy
Post by haynzy »
baaaa my dewalt battery drill would have done a better job, :mrgreen: :mrgreen:
Jafa
Post by Jafa »
haynzy wrote:baaaa my dewalt battery drill would have done a better job, :mrgreen: :mrgreen:
:lol: :lol: fawkin builders! :roll: :roll: :lol: :lol:
021 273 9942
jafa@inspire.net.nz
Jafa
Post by Jafa »
couple more of the transfer case side
021 273 9942
jafa@inspire.net.nz
Engineer
Post by Engineer »
its always a bonus when components fit!!
Jafa
Post by Jafa »
Got it finished last nite
and bolted up to the engine/trans...its looks long.... but its actually only 50mm longer than a 5speed and duals, so thats not so bad
021 273 9942
jafa@inspire.net.nz
Steve_t647
Post by Steve_t647 »
You decided to not clock the transfer cases?
But that does look cool, did you keep all the alloy shavings? you could almost pour them into a cast and get a second unit :D It does look very long tho are you thinking of having the lexus hard back in the engine bay for balance or are you thinking you will not use the standard body mounts and move everything back a little for better balance?
So with a Christmas time line and the new pace I guess it will be a little rough :P :lol: awesome work as usual keep it up.
Jafa
Post by Jafa »
Nah no clocking, its already gonna be flat bellied, upon reflection it might have been beneficial, but its already sorted so it stays the way it is. Such things will be thought about harder in the next build :shock: :lol: :roll:
The engine actually fits the bay really well, with a little clearance at the fire wall, but shifting the cab back a bit might be worth looking at.Radiator will be on the rear so front of engine clearance wont be a problem.
021 273 9942
jafa@inspire.net.nz
Jafa
Post by Jafa »
Got some work done tonite , only 5 months to go till RockRash 09! I gotta get my shit together!
Cut the output shaft on the auto
Tapped the coupler on
Installed the bearing and seal into the housing
bolted it up to the auto, heres 23splines waitin for some input :D
And here it is, 23spline input shaft
Also made a rear transfercase mount, kinda "Front Range Offroad" styles
021 273 9942
jafa@inspire.net.nz
lilpigzuk
Tiger Balm
Post by lilpigzuk »
go show them some north island reliability Jafa :mrgreen: :lol:
madaz068
Post by madaz068 »
Looks bloody good
timotheus
Post by timotheus »
So it will be Flat-Bellied then? What sort of clearance are you expecting under it?
Tim.
rokhound
Post by rokhound »
That is looking seriously cool jafa.
Be nice to see something down here that is built properly. :P :P (also be a first :lol: :lol: )
Jafa
Post by Jafa »
timotheus wrote:So it will be Flat-Bellied then? What sort of clearance are you expecting under it?
Tim.
Yer its flat bellied, I cant remember exactly how much, but I think its 700mm under the rails when its on 35's....wait till the 40's turn up 8) 8) :lol: :lol:
021 273 9942
jafa@inspire.net.nz
Jafa
Post by Jafa »
Started tackin up the 'zorst tonite
021 273 9942
jafa@inspire.net.nz
monaro427
Post by monaro427 »
jeez jafa i was just checking this out on pirate the pics of the exhaust etc :D
great work wish i could do that sort of work
MATT4U
Post by MATT4U »
so thats the zorst finished then jaffa?????? should be sweet :lol: :lol: :lol: :lol: :lol:
