Been a while since anything got posted in this thread
I think the only major work thats been done since that last post is that i have got the centers of my brand spanking new rims hacked out and reversed, new RS5000 shocks, front bump stop spacers added, and strengthened the front bar. Must get some more pic's.
I have just been driving it heaps around my parents place getting a feel for it. Its definatley starting to feel familiar when i get behind the wheel now, and i think its starting to show (i'm starting to break stuff
I've had it on two wheels a few times but managed to steer it out of a roll, so got a pretty good feel for the stability.
At the ORE BBQ, as you may have read, i smashed both U/J crosses out of the front D/S and ripped the T.Case out of its mounts.
I'm now running with my dodgy spare drive shafts untill i can find some SJ410 shafts but luckly had a couple of mint T.Case mounts on my spare T.Case.
Today i blew a rear axle with out trying, which is quite possibly a result of the hard hit that did the above damage.
Either way, its no good, especially as i have a super charger scheme in the pipe line.
So i'm on the look out for LJ80 diffs.
Why??
As they are a straight bolt in job, 100mm wider than the LJ50 diffs, stronger due to being designed to handle an 800cc 4stroke engine, and my diff heads with the 2stroke ratios will bolt in.
SJ gear has an offset front diff head, so not really an option other wise i would slap 410 diffs under it.
