vvega wrote:arh well i guess you will just keep goign and keep going and going and going
4.5 liters of lpg is to much ive talked to a desil man today ... a veyr clever one .. he seams to think that at idle because of the crap v.e you engine would barly use 6 liters of air a min to your 4.5liters of lpg ...with because of the presure of water is actually compressed so you dont even have a true 4.5 liters ........
... i showed him this threed and he laughed his face of
"of cause its going to det he throwing in a 80% mix of lpg"
A 3.9 litre engine turning at 700rpm using only 6 litres of air per minute?
I think you need to find yourself a better expert, that one doesn't have a clue.
The bucket is floating, the only increase in pressure is from the weight of the empty bucket (~60g) which spread over 75cm^2. That's a pressure increase of 0.06%. Insignificant.
As for the dyno plot, the torque they quote is corrected to flywheel figures. The stock 1HD-FTE had 440Nm, they only got 430.
Funnily enough, 430 and 440 together don't even make 970Nm.
