just curious to know if these breakages occured the first time you attempted the snatch, or was after repeated efforts and were all 3 of the vehicles fairly well bogged down
[/quote]
Yes all three happened on the first snatch and they were over 10 years ago.
The first one was in a timed section of a competition. We had won the teams enduro for the 2 previous years and had been told we were in the lead again, so it was win at all costs.
I got through the bog with a bank because of having a good approach angle . The cruiser got stuck. Because it was a timed section the rope was quickly put on and I took off. The cruiser slammed the bank and the rope broke resulting in the accident.
In this situation the bank should have been dug down.
On the 2nd one I got through the bog . The Nissan got really boged down with its big diffs dug in.
Earlier in the day I had broken a CV so had removed the axle . Because of being handicapped I thought I would need a bit more momentum ,resulting in the hook staightening.
We should have used the weight of 2 vehicles going slower and just power towing.
In the 3rd accident I was the only truck that got through the deep bog. The long wheelbase Nissan tried and was really bogged down. I weigh about 2100 and the nissan nearly 3000 so once winching failed we tried one snatch and thats when the tow hook snapped off.
It took 2 cruisers with 8000lb winchs, both winching to pull it backwards and then the trip through the bog was abandoned.
I am probably a slow learner you are probably thinking, but I did eventually get the point and changed the way I recover trucks. I still do more extreme 4 wheel driving than most people have ever seen, and for over 10 years now have not come close to an accident.
I know of one recovery in the lagoon of big river where 5 trucks were tied together to recover a cruiser that was stuck.
My argument is we should not be putting this extreme tension on our hooks and mounts.
If I do have to tow a truck I use a 24mm nylon rope.I take the slack up slowly and then feed the power on letting the stretch of the rope to do the work.
We need to be prepared to use a shovel or high lift jacks more to make the recovery easier.
Winching needs to be used more as well.
All of my tow mounts are over engineered, but this is only gives a false sense of security because a broken flying hook is probably more lethal than a bull bar , so we need to change the way we recover trucks and think things through rather than rip, shit and bust .
bulletproof
