My thoughts for what it's worthJust installed a 4WD Systems LOKKA in the front of my SWB GQ ( very tight standard LSD in the rear ) and at this stage I am very happy with the LOKKA's performance.
I originally thought a manually operated front locker would be the ultimate but due to the cost involved and after doing lots of research into alternatives I decided to try an autolocker. It cost me $505.00 AU delivered to my door and less than 4 hours to install myself which is a relatively simple task.
For what it's worth here are my thoughts and comments.
I have not had a truck with locking diffs before but have had years of experience driving 4WD tractors with lockers on steep hill country and alot of the same principles apply. ie.
Don't use locked diffs ( use wheel brakes instead ) on sidelings otherwise you slide sideways, and a similar thing when climbing offcamber hills and tracks in that you can lose your front end real quick if you break traction, also that you cant turn very well when diffs are locked especially going down hill.
BUT
An autolocker is an entirely different beast to a manually locked diff and the newer designs allow them to engage and disengage alot more easily. Most of the time you are not even aware that they are there except for a greater tendancy for the steering to want to "return to centre".
Iff the front wheels have got traction they will disengage and turn even if going down hill. If a front wheel dosen't have traction then 99% of the time you would want them engaged anyhow. I can turn while comming down a hill and the front end (if not rushed ) will turn and pull the front up the hill again whereas an open diff would result in the top front wheel loseing traction and spinning and then locking the manualy operated diff would result in it sledging straight ahead. When turning on steep sidelings (if I take my time) by blipping the throttle it actually causes the backend to break traction and slide sideways, great for getting around those tight corners. I can climb a hill where you can only get up with locked diffs and as you come onto the track at the top you can turn because at that point they have traction and will allow themselves to disengage.
Some guys with manual lockers say they dont use then untill they really have to or are stuck. TO LATE !
OK there will be times that I may curse the fact that I cant turn them off but at this stage I feel this is more than compensated for by them working automatically maintaining traction all the time. Sort of like stability control in modern vehicles - sometimes a bitch, but most of the time allowing you to do more and easily.
AND if in time my experience with them turns out to be wrong and that what I have written is total bullsh!t, then I can allways take them out and sell them for half price and it won't have cost me much.
PS
Just cleaning out the office and found this old clipping from the local paper.
Don't think it would make any difference if he had lockers or not!
