27th - 28th, Xmas over and done with.
UBZ
Re: 27th - 28th, Xmas over and done with.
Post by UBZ »
mercutio wrote:been tinkering on the g and got it running finally and it does sound good even moved it under it's own power even if it was only a metre :mrgreen: :mrgreen: :mrgreen:
Was it the computer or just dodgy wiring?
PR
In the crap again
Post by PR »
Well my weekend was on the 29th :( But I managed to put new roters and pads all round and totally rebuild my front axle, new bearings, seals, CVs and Hubs thats what happens when you wire up your ARB switches around the wrong way :shock: :roll: so alls I got to do now is a bit of welding / service winch/engine/gearbox/transfercase and rear diff and get a Cert :x so I can get a WOF :D then I will be able to play finally :twisted:
(021) 02388443
PR
In the crap again
Post by PR »
Oh and I forgot :oops: wire up ARB switches around the right way :oops: :oops: :oops: :lol:
(021) 02388443
gary_in_nz
Post by gary_in_nz »
PR wrote:Oh and I forgot :oops: wire up ARB switches around the right way :oops: :oops: :oops: :lol:
so what did that do to your diff and things?? is the locker ok??
PR
In the crap again
Post by PR »
Locker is fine :mrgreen: just blew the CVs and Hubs on both sides :shock:
(021) 02388443
mercutio
Post by mercutio »
UBZ wrote:Was it the computer or just dodgy wiring?
neither it doesn't have a computer and the wiring is just as dodgy now as it was when the problem started
the main thing i learnt in this exercise is if you flood an engine lots and lots your engine looses compression and the oil gets very thin :oops: :oops: :oops:
my 4wd is not a truck
