NJV6 wrote:
Diahatsu using every last drop of power to run the winch....
crank driven ?
by the sounds of it .. if you dropped back the cc's of the pump a little more you will loose ultimate pump flow and NO LOAD speed ... but you woudl gain shaft hp over the entire rev rage and thus actually go faster under load
thats why when you size a pump you size it so max flow is at max rpm so that if you do begin to bog the flow drops and with that the hp required to drive it kinda self govening its not a ideal setup but im guessing you have no relief valve
ratio's is everything with hydraulics you only have to be a tiny bit out to get it alll wrong :d
that is some impressive speed though ... the other option is making more power
how it shoudl be setup is so that at relief pressure the motor is still able to drive the pump well .... because that is the maximum load it can ever see you wont get it slowwing untill ethier the winch actually stalls or the line snaps
please remember i dont know a lot about 4wding .... but i do have a very good understanding of fluid power systems
hope that helps
